Alright I keep hearing its cheaper to build your own turbo. First how much cheaper I'm looking at 350 to 400 hp. Second can someone put up a good complete parts list that I can go off of.
hey alex, remember that one thread that i posted in about someone wanting to boost there car over the summer.. Same kinda deal hereYou're going to turbo your motor and are hoping to get 350-400 but don't know what stuff you need to build a complete setup?
agreedYou're going to turbo your motor and are hoping to get 350-400 but don't know what stuff you need to build a complete setup?
Haha yeah, but the other guy didn't seem this hopeless.hey alex, remember that one thread that i posted in about someone wanting to boost there car over the summer.. Same kinda deal here
If you don't want to blow up put lower compression pistons. Whatever type R pistons are, they're too high for too much pounds of boost, unless you're sleeved and blah blah. Why turbo a type R though? Those are great N/A motors, use it what it was made for and build it N/A. If you want a boosted motor, get a b18c1 or b18byou are going to need a lot more than a turbo kit. i dont think the treadstone kit would be ideal for your goals of 350-400whp. that log manifold will be quite a restriction, as well as the downpipe which i think is 2.5"
on top of that the stock motor could make the power with a good tuner but would be pushed beyond its reliable limits at that level. a simple piston and rod build on the stock sleeves would work.
dont forget your fueling and engnine management which are not included in the kit. larger injectors, a walbro 255 fuel pump, chipped obd1 ecu tuned by a qualified tuner.
