Turbo related
1999CivicEX
I feel retarded but is a t3 turbo good to push between 8 - 10 lbs of boost or is it overkill?
DetainedCivic
I haz SR20
you can do it
1999CivicEX
I guess I should have stated the question better. What I mean is it going to have a lot of lag, quick spool up, I know it can handle 8 - 10.
Shiznit
Stickin it to the Man
that depends on what size the turbo is and the application, which you havent specified
1999CivicEX
Garrett T3/TO4E 57 trim
COMPRESSOR SPECS: flow: 53 lbs/min 678cfm .60 A/R HOUSING 60 TRIM WHEEL TURBINE SPECS: A/R HOUSING Available .48/ .63
http://www.spoolinperformance.com/garrett-t3to4e-trim-p-30.html?osCsid=532e8e3672e581f75a785fb0ccfb2792
and this will be going onto a d16y8
going to use this mani
http://www.spoolinperformance.com/streetpower-p-50.html?osCsid=532e8e3672e581f75a785fb0ccfb2792
This wastegate also
http://www.spoolinperformance.com/tial-38mm-wastegate-p-180.html?osCsid=532e8e3672e581f75a785fb0ccfb2792
Also going to run 3 in exhaust
All this was suggested to me by a friend I just don't want to buy the crap and have it not put down some decent numbers and be laggy
This wastegate also
Shiznit
there will be lag but it wont be too much
1999CivicEX
so you think this setup so far will be alright? NOt sure weather I am going to waste gate it to 8.5 or 10.2
Shiznit
yeah you have a decent size turbo. lag shouldnt be terrible. the rest of your setup looks legit, for 650 you can get a better manifold though... dont be afraid to buy used parts, they will save you money. things like your manifold can be bought used for much cheaper. standard 38mm tial wastegate is good. 3" exhaust piping will be good
EDIT: the bigger the AR the bigger the turbo and the longer the lag but the more hp it puts out.
Sleeper
92 4doorSleeper
This wastegate also
This wastegate also
that is alot of turbo for a stock y8... the size is over kill. go with a smaller turbo & boost a lil more to make of for the power deference. on a stock y8 that turbo will never see it full potential
1999CivicEX
stock ;) Actually I bought a sleeved block off a friend for $800 since he wrecked his car. has lower c/r rods
I am just figuring out certian things first that way I don't have a setup that doesn't do to much for me
1999CivicEX
I will most likely go used on some parts I just remembered that website so I figured I would put stuff into the cart and see what it totals
1 x External Wastegate Gasket (35-38mm)
1 x Tial Spring - Small
1 x Tial 38mm Wastegate
1 x StreetPower
1 x Garrett T3/TO4E 57 trim
1 x Apex-i AVC-R
1 x SPoolin 27X6.5X3.5 intercooler
1 x EG/EK/DC Steel FMIC piping kit << Will just make custom piping
1 x T3/T04E Oil Feed/Return kit
1 x Oil Return Gasket - T3 or T04
1 x T3 Inlet Gasket
1 x 2.0-2.50 Silicone Transition Coupler
3 x 2.25 straight coupler
$2,604.50
Handlebars
None Taken.
your list looks good, but you've forgtten one really, really important part- fuel managment.
Sleeper
92 4doorSleeper
1 x StreetPower
1 x Apex-i AVC-R
1 x T3 Inlet Gasket
$2,604.50
lots of cash there.. I did my whole s**t for 800 including fuel managment(excluding all the new stuff for my big poower setup), just to show you how of an over kill that turbo will be for you Im getting tuned for 550+whp this coming month & my compressor A/R still is smaller then the one you listed & i have a built 9:1 GSR.
Sleeper
92 4doorSleeper
big time. no go with no tune.
1999CivicEX
I am getting a chipped ecu from phearable.net and tuning with chrome thats why there wasn't anything listed
Sleeper
92 4doorSleeper
you getting a chip burner? whos doing the tuning with Crome, dyno tuning or street tuning? what injectors, fuel pump, getting a wideband?
1999CivicEX
Since you think this is overkill what would you recommend. 8 - 10 lbs is only going to be while I am breaking the motor in. Then I plan on cranking it up Sleeves can hold 40 lbs boost easy is what I was told by a dealer
1999CivicEX
Wideband I am going to get an aem, place has a chip burner. Since I work I will have to drop the car off at a place so I will tell them street and dyno can't go just dyno. 370cc injectors on a welbaro fuel pump havn't decided on which one
Sleeper
92 4doorSleeper
T3-50 Trim would prolly be the smallest id go for a set up as yours, it would be fast spool & good output. next up the bigger T3-Super 60, lil slower spool, but lil better power output.
