Turbocharger vs Supercharger
Blazed
f**k The Powers That B
neouser said:
Supercharger vs. Turbocharger : An editorial (aka - Why both are good.)
Ok, we've seen it brought up a million and one times, so, I'm going to give my take on the whole turbo vs. supercharger arguement once and for all. Honestly, both devices ROCK. They essentially do the same thing (which is pressurize the intake) when it comes down to it. Argueing that one makes "more power" than the other is utterly redundant, as I re-iterate that they both essentially do the same thing. (Look up redundancy in the dictionary and it will say "See Redundant".) Anyways, I'm going to write this blurb based on the assumption that anyone reading it has grasped the basic concepts of how a turbocharger and supercharger work.
Typically, the arguement is that a turbo makes more power than a supercharger, which is not entirely true. For instance, the Lysolm (aka "screw-type" Supercharger, known as the PSI in Top Fuel) was the choice of forced induction for Top Fuel cars for years until they were banned for giving an unfair advantage to the cars using it. If it's good enough for Top Fuel, it's good enough to make some pretty good power on a street car. Now, don't get me wrong. I'm not telling anyone to run out and buy themselves a supercharger right now. In fact, I'm not even implying that it's better than a turbo. I'm just making a case for it. Just as I'll make a case against the idea that turbos are all about lag and disproporational power curves. That's not entirely true. A turbo compressor that is well matched to the motor and tuned properly can result in a car that makes power smoothly over a broad powerband. Per a conversation with Texan, the Audi R8, a LeMans car running in the LMP900 class, is a good example of a turbo car that drives like a very powerful all motor car.
Admittingly, both Top Fuel cars and LeMans cars are not the best examples of your everyday street turbocharged/supercharged car, but it's to make a case that either device can be good IF the car is properly tuned with it. Most of the myths about turbochargers and superchargers come from people that buy "kits" and slap them on their cars without any real tuning.
So how about Honda cars? Why does the turbocharger seem to be the definite forced induction of choice for these small inline fours that barely have enough displacement to hold a two litre bottle of soda? Because current turbo kits have more options and more room for expansion. Currently, the almost limitless availability of different sized turbos and intercoolers allows for a great deal of very detailed tuning. There are turbochargers galore that can be matched to suit an engine's flow pattern and needs, with a plethera of intercoolers available to compliment the compressor of choice. Most superchargers just don't have that option. (I'm mainly talking about Roots based superchargers. I've touched on the reason why I feel that centrifugal superchargers are poorly matched to the small displacement motor in an article in the Supercharger Forum.) Adiabatic efficiency is supreme when it comes to a boosted intake charge, and there's no getting around the benefits of an intercooled setup. In fact, other than a motor's limitations regarding the amount of power it can hold, the only other limiting factor when it comes to boost is the amount of boost you can make before the intake charge is heated so much that you see a loss in power. An intercooler allows for a cooler charge after the air is compressed, which allows for more compression, which, in turn, allows for more cfm of flow from the
compressor. More air being moved is always a good thing. Why?
(Air + proportional fuel) x being burned = Heat/3 = Power produced
So the more air that goes in, the more fuel you can burn, and the more power you can make. In that respect, it doesn't matter if that 150 extra cfm at 4000 rpm comes from a supercharger or turbocharger. 150 cfm at 4000 rpm is 150 cfm at 4000 rpm. However, the real important stuff happens somewhere along the way between the turbo/supercharger and the head. Boost is that cfm of air being compressed in the plenum, and how dense that intake charge can be is very dependent on how cool you can keep it. So we understand how an intercooled turbo setup is beneficial, right? Good. With that said, provided that both the turbocharger and supercharger producing the same cfm of flow that isn't intercooled, you'll see similar performance out of either. (Admittingly, the draw from the crank by the supercharger will show a slight drop in power in the end.)
Let's look at another factor we should take into consideration. Altitude. As everyone knows, the higher the altitude, the lower the air pressure. How does that relate to choosing between a supercharger and turbocharger? Taken into account that the devices relies on a supply of ambient air being fed through it, the relative air pressure can make a gross difference. As a general rule, turbos aren't affected much by altitude, provided that the wastegate is venting well below surge limit. The wastegate is controlled by pressure in the intake tract and will allow the turbo to continue to make boost until a pre-set limit, which is when the wastegate will begin to vent exhaust gasses to prevent excess pressure. So, in layman's terms, a turbo set up to make 12 psi in the plenum will make 12 psi, regardless of ambient air pressure. On the other hand, a supercharger will always move a given amount of air, and, given lower air pressure, will not compensate by spinning up to a higher rpm than the engine dictates. That gives the turbocharger a definite advantage in that respect.
To be fair about it, though, turbochargers do have boost thresholds. Under a certain RPM, there just won't be enough exhaust gasses to make boost. Whereas the low RPM positive displacement pump will make boost off idle, the turbo REQUIRES engine load to spool up. When I said that the turbo could make a wide range of power smoothly, that didn't mean that all it's weaknesses could be eliminated. It just meant that some of them could be compensated for. A smaller turbo could provide boost earlier in the RPM range, and could provide more than enough flow to cover a good 5000-6000 rpm range before you hit compressor surge. (It can also reduce lag and make the car feel very responsive to the throttle.) Good tuning could reduce boost "spike" and can make power production feel even and natural. But you can't get around boost threshold. You need a certain amount of load to spool up the turbo. That's just the way it is.
So far, as a sum of the whole, the turbocharger definitely has the advantage over the supercharger. So why supercharge if the turbo is so much more effective and versatile? Simplicity. A turbo can make smooth power reliably if tuned VERY well. The dynamics behind setting up a supercharger are much simpler. With parts that compliment the nature of the blower (i/h/e, cams, breathing stuff), it's all a matter of tuning the right timing and air fuel. It is that much harder to combine parts to make an effective turbocharged setup. (More options = more complex. Look at the difference between setting up your high-tech MP3/DVD playing car stereo vs. your dad's big button and knob AM only car radio.) In the real world of a daily driven street car looking for added power, there's nothing easier than bolting on a supercharger. Add in the natural limitations of the motor govering the amount of boost it can handle, and the amount of power a positive displacement pump provides begins to seem less disappointing. In a daily driver, the supercharger is the epitomy of useable power. Throw in the use of a Lysolm, such as the Rimmer kit for the Civic Si, and you're looking at a LOT of useable power.
So let's wrap this up. What's the bottom line? EITHER a turbo OR a supercharger would be a great way to add bolt-on power. The one you use solely depends on your preference, how much money you have to spend, and how much time you have to dedicate to your project. Either a turbo or supercharger requires tuning to put the power it makes to it's best use. Just because you choose a turbocharger doesn't mean that you have to sacrifice responsiveness, just as a supercharger doesn't mean that you have to sacrifice good power output. I'll admit that the turbo is definitely the poster child for a serious race tuner, but I wouldn't discount the supercharger, since most of you people reading this spend more time on the street than the track...
Civic-Duty
duckin' and divin'...
nice read, any idea on where he got it from??
Blazed
check out hondalife.com ;)
J32a2OwnsU
Resident Old Man
Great find blazed!!!! =)
$lick Rick
TEOTWAWKI
so according to that write up.. a theoretical non-existant supercharger could possibly be just as beneficial if not more so than a turbo charger on honda engines...
but even according to him, at this time that supercharger doesnt exist for hondas, so the guy is doing nothing but blowin smoke out his ass :lol:
Shiznit
Stickin it to the Man
richocet1 said:
Can this be stickied...PLEASE!!!!
Oh, and REPOST! :lol:
no, however the link has been added to the sticky thread
Blazed
seemed legit to me :what:
LowNotSlow
Aqua Teen Christmas Force
I don't think your reading comprehension is that good. He didn't talk about a theoretical supercharger. In fact he mentions one by name Rimmer. And the type, Lysholm. So where you're getting theorectical is beyond me.
J32a2OwnsU
Resident Old Man
he also mentioned the 'screw type' superchargers with that group....
LowNotSlow
screw type would be a roots style supercharger, which utilizes two screws.
King Bob
The life'o Riley
I think the guy knows his s**t, I think that because he just made a long winded version of I always say.
$ = power . $$$ = more power.
J32a2OwnsU
Resident Old Man
exactly....... =)
I think Endyn also makes a much more efficient than stock supercharger too that boasts as much potential power as a turbo does......
oh well this debate shall live on!!!!! lol
$lick Rick
TEOTWAWKI
yes, he talks about those in referral to "Top Fuel cars and LeMans cars", not honda's... and there in lies my point
we own honda's and must make due with pre-fabbed s/c kits.. the types of superchargers he's talking about either arent produced for hondas, or arent produced to out perform a properly done turbo
Blazed
well his whole view is that u can use both to make good power...
it really comes down to money and preference...
stephen prefers t/c whereas the other dude prefers s/c...
i posted a couple more threads in the F/I section from that same site...great info IMHO...
p.s..Todd needs to learn how to reply to pm's..:kickass:
vandynamics
its good info. but not great info. its more of a desperate attempt to solve a problem that many people have without gving good specific deductive reasons. one reason why a turbo charger is superior is because the wastegate allows a turbo to stay spooled in an optimum range, superchargers cant. even though there is "turbo lag" it is still a superior setup. I would rather have an optomized wastegated effecient spool at 6000 rpm, then a quick spool at idle.
Blazed
^^ sounds more like preference ;)
LowNotSlow
and that my friend is the crux of the issue
King Bob
The life'o Riley
absoultly, Its about prefrence plain and simple. I think the author did about as good of a job as possible of describing the pros and cons of both systems without being descriptive enough to pidgon hole himself while being descriptive enough to be relavant. He clearly left it up to the reader to select the best application, for there needs, themselves.
