Turbocharger vs Supercharger
FRODO
oh well i am still s/c my si.
King Bob
The life'o Riley
when did you get an si vic? Last I knew you were still rocking the EJ6
FRODO
:lol: like three months ago....2003 blue Si. :thumbs up:
King Bob
The life'o Riley
Dude wtf I am so out of touch :oops:
:thumbs up thats awesome
Panathrasher
From www.jacksonracing.com
Q: How does the Supercharger compare to a Turbo system and does it need an intercooler?
A: Jackson Racing has been in business for over 25 years doing high performance Honda/Acura tuning and we speak with some sort of authority on the subject of Turbo vs Supercharged Vs Intercooling. Having built turbo Hondas since 1976, the first turbo/intercooled CRX's in 1984, and having run the first turbo/intercooled Honda at the first Battle of the Imports in 1990, we do have experience with all of the above issues and can speak, without bias, having done so. And, having seen first hand the long term effects of turbochargers on daily driven high compression Honda/Acura engines, we have opted to supercharge the future.
For ease of installation, instant power, and low cost, nitrous is the only way to fly. However, that is if you only want to go drag racing. If you want everyday nitrous type power, you have to go to forced induction. That is where the turbo Vs supercharger debate comes in. For absolute peak power where driveability, turbo lag, emissions, and long engine life does not need to be taken into consideration, turbo is the only way to go. But, with all things in this life, there is no free ride. With a properly designed turbo charger system you have the ability to produce huge amounts of boost and horsepower easily. The problem with that amount of boost is that once the turbo spools, it goes to full boost. There is no linear delivery of boost.
Consequently, if the turbo spools at 3000 rpm, you have full boost at a valve speed that is very slow. So, the turbo has lots of time to create cylinder pressure on the rods and pistons because of the very long time that the valve is open. This, in turn, is what creates that huge rush of power when the turbo spools. This is also what causes so many turbo engine failures. Combine that with the fact that the compressor sits within 2" of a glowing 1300 degree cast iron oven, the charge air temperature is always very high. This has created the myth that anything with forced induction has to be intercooled. If you have checked the intake temperature of any of the late model O.E. manufactured intercooled turbos, at the intake manifold, not the outlet of the intercooler, you will find that the intake air temperature is near 200 degrees, even after the intercooler. As an example, a test by Sport Compact Car on a new model Turbo/intercooled German built car, they found the charge air temperature at the throttle plate to be 206 degrees after the intercooler. You see, the intercooler is a great thing as long as you have steady air flowing over it. If you are doing a lot of starts and stops, the effectiveness of the intercooler is diminished. Secondarily, once the air has been cooled, it has to be routed back to the intake manifold. That means that it has to come back into the hot engine compartment and the tubing re-heats the air. Not a lot mind you, but it still happens. Equally important, you have to fill all of that tubing with boost, then, when you shift and the bypass blows open, it empties the tubing, requiring the tubing to be refilled. This is the main cause of poor throttle response and the classic turbo lag in a intercooled turbo car. Now, keep in mind that this is all a mute point if you are at speed. But, then you have to stop. Once you stop, you have to cool the turbo. And heat, being the heart of the turbo, is also the enemy of the engine. To further the intercooler debate, let us consider the Ford supercharged/intercooled T-Bird and the GM (Buick-Pontiac) supercharged/non intercooled cars.
The Ford uses a 90 c.i. Eaton supercharger with as much as 14 psi and an intercooler. GM uses a 62 c.i Eaton supercharger with 8 psi and no intercooler. GM mounts their supercharger "Hot Rod" style, on top of the intake manifold as close to the intake valves as possible, with no intercooler. GM's approach, it appears, is to run less boost and thereby, less discharge temperature, and mount the supercharger as close to the intake valve as possible for maximum driveability. Ford's approach seems to be to go for the maximum effect with an intercooler. But, to push the charge air all the way out to the grill, through the intercooler, and back to the intake manifold, requires a larger supercharger and large quantity of boost. Thus, the 90 c.i. supercharger on the T-Bird and the 62 c.i. Supercharger on the GM models. In the final analysis, both engines have an identical horsepower reading. I am sure you are asking yourself "How can that be?" It is in the systems efficiency.
The GM system appears to be more efficient overall. Less load from the supercharger, intercooler, and all of the related plumbing equals better throttle response and an overall better driving package. Now, I am not saying that an air to water intercooler, mounted close to the engine would not be a great piece, it is just that in some engine compartments, it is not possible to package it. So, intercooling is fine if the system is not parasitic by design with plumbing running everywhere, and the net effect of the intercooler system in day to day driving, and that is what I am speaking of, is positive.
