How long would you guys recommend warming up a boosted civic in the morning? In the winter? and in the summer?
same here...my car seems to run better once its warmed up.....i usually wait between 1-3 mins b4 i drive off....in freezing winter ill probably wait around 5 mins b4 i drive off....or atleast wait til i see the temp guage starting to go up...youve got full oil pressure by 30 seconds or so. depending on the ambient temperature youre motor should have normal operating temps after about 5 minutes. i dont drive mine til ive hit 150F on the water temp gauge... she just drives better warm
that's how you cool your engine down.^^ cranking the heater on full will make the engine take longer to warm up. but i guess if you wait long enough then you'll have that toastiness you desire
unless you live in Chicago,If you work in the morning in winter, the best thing to do is run outside, fire up the G ride, turn the heater on full blast, run back inside, get dressed whatever. By the time you sit in your car with the heater on, you'll be warmed up AND your car will be warmed up. And you can do whatevaz youz lieeeeek.
