wastegate problem
TiiM iiS l3eAsT
Scamming Piece Of s**t
alright after really lookin at it i put my turbo/adapter plate/hf manifold together......and well im almost positive my internal wastegate is going to hit the block....idk heres some pics of it.....ive measured it and i went out and looked in my engine bay and its gonna hit.....what can i do???? i dont wanna switch over to a external wastegate though.....
Steven.
Formally Green 91
test fit, might need to rig something up.
or get a custom plate that rotates the turbo. or go external gate
Shiznit
Stickin it to the Man
:shock: thats the first time ive ever heard someone say that
Steven.
Formally Green 91
i would RATHER have external, much more reliable. controls boost better also.
--<EM1>--
boosted ftw
ive seen people cut the block near the tranny but i might be wrong.
d-series? i would test fit. can't hurt at all
io_303
NIFOC
you might need to grind the webbing, but the only way to tell is to try it.
Handlebars
None Taken.
i have a horribly complicated idea. turn the turbo around on the manifold. problem solved.
io_303
NIFOC
Sure, do it the easy way...
Steven.
Formally Green 91
then it would hit his rad.
ryan89crx
Spoolin single cam!
more reliable? i dont think so. able to support higher boost levels and power output better? sure.
if external were more reliable, all factory turbocharged cars would be extenal. i think that the 99% that run internal might know that internal is extremely reliable considering the warranty and vehicle longevity they have to think about.
on thread topic, chances are it will hit the block. its a t3 right? from what ive read almost all t3 internals hit the block with a HF manifold :???:
TiiM iiS l3eAsT
s**t yea its a t3.....ill just test fit it and we'll see how it goes from there
RKSskier
Damn you and your LOGIC!
Handlebars
None Taken.
which is why most turbo guys run a half size radiator. you can get them on ebay for 150 bucks. its the only way thats gonna fit, unless you dont mind grinding your block down to the water jackets.
ryan89crx
Spoolin single cam!
i bought one of those 1" thick core aluminum half rads on ebay, the ones that run like $45 shipped..
been working great for 1.5 years now, cant complain at all
Shiznit
not to thread jack or anything but i live in the desert and can see temperatures as high as 120*, how well do you think the 1" core radiators will stand up to that heat on a turbo b16? or can you recommend a good size radiator so i dont have over heating problems
ryan89crx
Spoolin single cam!
i live in the desert as well and see 110+ pretty consistantly. if your rad is properly setup(like stock so no air moves past, must go through) the radiator should cool just fine. if not, there are those Mishumoto or whatever rads on ebay for about $150. they are 2" thick, and solid aluminum, no plastic endcaps like mine.
Handlebars
None Taken.
any all aluminum half size with at least a 2" thick core (a 2.5 or 3" is best for a turbo car) and aluminium tanks should be just fine.
TiiM iiS l3eAsT
hmm...i dont have a ac bracket so im not worried about that......whats that D logo flange do??? just make it stick out a little?
