theres 2 fitting on the wastegate one on each side of the diaphragm.
a manual boost controller only needs the lower one. it just limits how much pressure is going to the wastegate. the electronic one uses both fittings with a solenoid that shifts back and forth to equalize pressure and hold a steady boost plot.
so if you are running a manual boost controller just remove the fitting entirely and you shouldnt have any problems.
