im not sure what ohm my subs are. i cant find that sub anywhere on the internet to find out. from what ive researched its best to wire 2 subs to a mono d class amp instead of a 2 channel becuase its a lower independency or somethin. how would i wire these to subs to a mono amp? there is one set of voice coils on each subs so only 2 wires coming from each
since you dont know the resistance (ohms) of your subs, the best way to measure it would be to measure the resistance with a multimeter (you can pick up a cheap one for 10$ just about anywhere...thats all you need).
everything below is based on having two single voicecoil subs...keeping it simple. using a bridged 2 channel amp or a "mono block" type of amp.
if you have two 4 ohm subs and you wire them in parallel, you get a 2 ohm load.
if you have two 4 ohm subs and you wire them in series, you get an 8 ohm load (probably not what you are looking for).
if you have two 8 ohm subs and you wire them in parallel, you get a 4 ohm load.
if you have two 8 ohm subs and you wire them in series, you get a 16 ohm load (definately not what you are looking for).
i thumbed thru this link, and it might help a bit...
http://www.termpro.com/articles/spkrz.html
I recall something in this thread about someone having an amp that always got hot (maybe it was you) and ended up blowing. this is common if subs arent wired at the correct load rated for the amp (example, if your amp only goes down to a 4 ohm load when bridged and you run a 2 ohm load). on a good amp, sometimes you will get away with it for a while. if its a cheaper amp...pop!
but again, just get a multimeter and measure the resistance of the speaker, or bum one from a buddy. after you wire your subs, you can always verify the load is correct by measuring from the positive and negative wire BEFORE you hook them to the new amp.
