Same thing happened with motor everything seemed fine (97 d16y7) bought it last Monday was installed Friday . It had white smoke when first turned on I figured it was build up from my last motor. It went away but on Saturday, I noticed when you accelerate in 1st-4th the white smoke comes back not alot but it's noticeable I'm like fml here we go again. Then today after work I decided to check my oil level bone frickin dry. Doesn't leak on the ground just disappears.That's alright, the sixth gen civic EX I just bought needs a 2nd gear synchro. Test drove it and it did fine, even did fine all that night, but the next day it started popping out of second. Oh well, gonna buy and build a used transmission and skip 2nd for now. s**t happens I guess. Good luck with the motor man, listen to anfrey and run a compression test.
Well if you were burning all that oil, your smoke would be blue.Same thing happened with motor everything seemed fine (97 d16y7) bought it last Monday was installed Friday . It had white smoke when first turned on I figured it was build up from my last motor. It went away but on Saturday, I noticed when you accelerate in 1st-4th the white smoke comes back not alot but it's noticeable I'm like fml here we go again. Then today after work I decided to check my oil level bone frickin dry. Doesn't leak on the ground just disappears.
Edit: I'll have to see where to get the compression test
Sent From My Evo 4G Amped Up On Verizon Tower Power!
you can replace tha 2nd gear synchro this weekend and be cruisin by sunday night if you know what you're doing.That's alright, the sixth gen civic EX I just bought needs a 2nd gear synchro. Test drove it and it did fine, even did fine all that night, but the next day it started popping out of second. Oh well, gonna buy and build a used transmission and skip 2nd for now. s*** happens I guess. Good luck with the motor man, listen to anfrey and run a compression test.
It might be blue I'll take a video next time I drive the carWell if you were burning all that oil, your smoke would be blue.
you can buy a test gauge at your local auto parts store. it's really easy to do. this is to help narrow down the issue and figure out the cause by process of elimination. good luck!I'll have to see where to get the compression test
EW why?!Put my EM1 up on Craigslist. Hoping to find a clean EM2 for sale.
i'm usually up at this hour. my wife goes to work at 6am so i try to make sure she's awake around five.i figured i was the only one up this late man.
