Mas0n
In my budget i wasnt including the tune, i was just saying for the set up. And im not going to buy cheap parts, i was talking about what upgrades on my motor do i need to support the turbo, as in internals without rebuilding the whole motorthe bare minimum needed to support it shouldnt be a statment when talking about a turbo build. IMO
if you cheap out on the wrong parts no more motor the parts would be alot cheaper.
Also what are you going to tune it on and whose going to tune it the backbone of a turbo build is the tune you can have every baller part in the world no tune or s***ty tune and it either wont run will mess something up or run horribly
replace the things that need to be replaced on the motor
arp bolts
the bottom end should be fine at those goals
injector size or your choice
walboro 190 or 255 fuel pump
fuel rail and fpr
and then everything else that goes along with a turbo build that list is just scratching the surface dosent even really get into the turbo kit.
Then the program or way you are going to tune it and the tuner whoes doing it
