I'll go 50/70/90 (3/4/5th) but there isnt much left at that point, so Id rather just kick it in where the heart of the powerband begins, ride that for a few sconds. Rather then downshift to the end of my power to shift again (which clows you) 2 seconds later. Just preference.Going-West said:i do that a little different. if im going 80 i put it in third cuz 3rd tops out around 90-92ish, 4th gear around 110, 5th gear 135, i shift to the lowest possible gear when downshifing to be at max power the longest. so basically if im going 10mph or under the top speed of THAT GEAR, i would downshift to that gear, to be closest to max power the most
racing. it really depends though, normally when u do a running start, you are already in the right gear. But 60-100 say, Im in 3rd b/c 2nd is redline at 60.. 70 and up i still start in 3rd. 80 or up i start in 4th.Going-West said:are you talking about just driving or downshifting to race?
MySiIzFaster said:Thats also impossible man....unless u changed the gears, top speed for a 00 si is 135 @ redline.
oh word....Going-West said:sorry guys i just tested it my em1 tops out at 173 going downhill, with 1/4 tank and 4 shots of octane booster, against the wind. i wasn't even out of 5th yet, i still had reverse to go into but i ran out of road
when i topped mine out i went past 8000 i went to about 8300-8400 an all other gears and the speedomater was the two little hiars past 140 so i guess 144 and i am pretty sure i wasnt at 8400 yet....Going-West said:ive seen that too, but that car can go past the redline i think he prolly went past 8k in his other gears. cool though! i didnt say it can't go 140, i think the si can go 140 topped out in 5th if conditions are right
Fuel cutoff/revlimiter is at 8300 man....... unless your modded.BLK_B16A said:when i topped mine out i went past 8000 i went to about 8300-8400 an all other gears and the speedomater was the two little hiars past 140 so i guess 144 and i am pretty sure i wasnt at 8400 yet....
oh you know your jealous92 4DoorSleeper said:oh word....
this is true, i hit that s**t once, i was like f**k! when it happened. i was pulling out of a neighborhood all slow, and just when i started o go straight i floored it, lost traction and the revs went up quick and then it just was quiet, i was driving very slow the whole way home.MySiIzFaster said:Fuel cutoff/revlimiter is at 8300 man....... unless your modded.
So you like my theory on the 0-60 thing (shifting at 8200 right before the limiter saves you .1 or .2 on times)...Going-West said:this is true, i hit that s**t once, i was like f**k! when it happened. i was pulling out of a neighborhood all slow, and just when i started o go straight i floored it, lost traction and the revs went up quick and then it just was quiet, i was driving very slow the whole way home.
well, redline in 2nd is 58MPH, so if you dont have to switch gears to get to 60, Im sure it will help at least .1 to .2 or so........Going-West said:well im going to the track sooner or later, cuz i wanna do it a couple times before the high school drags so i can get used to it, ill try it, prolly not the greatest for the engine, but on the next shift your revs will be higher so in theory it should work
