Juliette
My car leaked all the oil and no light ever came on; there is oil mostly from middle to right side of VTECH engine.
I read up on it and found that the pressure switch probably is not working. I'm out of work and looking but cannot afford to take it to the shop. So I replaced the oil and it has leaked again with no warning.
I looked up where the switch should be and it turns out that there are 2 switchs next to each other and the
guy at the parts store did not know which one was the right one.
I've been reading different forums and don't find any info on which one it is. I cleaned the oil under both
switches and sometimes it seems the one in front is leaking fresh oil, but at times, it seems the oil leakes
from in between the distributor cap base and the engine.
I was thinking of removing the spark plug wires (they are numbered) and removing the base of the distributor cap to ck if it's the engine tha's leaking, although I doubt it because I previously replaced the head gasket seal.
I need to know which is the right seal, and how to change it. Do I need to take any other steps before removing it?
Thanks in advance.
Thanks in advance.
