Ok, guess ill chime in too.
I decided on the h22 mainly for the torque. Because as the saying goes "Torque wins races and HP sells cars." I also chose it because there arent too many of them runnin around where im currently living. But mostly for the numbers. The torque numbers, the hp numbers, the price tag numbers. All those numbers were a factor in my decision.
And no, you dont have to be rich to do this swap (if you did, i would be the last person doing it), you just need to have patience.
And no, you dont have to buy a power steering pump and no it doesnt have horrible under steer. These are wives tales. You just have to make sure to take your time and do it correctly. No cutting corners (just like any other well done swap should be).
And yes, you can boost an h. You just have to be very careful with the amount of boost your pushin. The reason is because the cylinder walls in the h are very thin. In which case, if you really wanted to boost the hell out of it, you could, all you would have to do is resleeve and you'd be good to go.
And yes you can have AC. HCP makes a bracket that allows the AC compressor to be mounted on the motor.
