dont worry i have plans to plug up the holes....well i got it started yesterday......turns out my oil feed has ANOTHER leak......this time its actually in the line though and not in the fitting.....
can i ask....did u cheap out on the fittings and line?
ALSO when ever i turn on my headlights (HIDS) it will kill the radio.....well i thought the grounds were to long so i shortened them ALOT and it helped a lil bit.....but it will still kill the radio so im stuck on that part......??? the only weird part is the brights work just fine.....like if i have the car OFF and i flick on the brights they have no probs what soever.....when i turn on the HIDS they will work for about 5 secs.....start to flicker really bad.....and then just turn off.....so im not sure whats up with that yet...
that sounds like a bad ballast with the flickering. can i ask....did you cheap out on the HID kit? Plug N Play ebay HIDs?
as far as the radio goes, thats odd. try testing power to the radio and see if you are losing 12v or if the radio has an internal issue.
when i tried to tuck the throttle cable....well apparently you cant do that.....bc when i went for a drive the idle was stuck at around 2 grand.....its like its not letting it go back to the normal rev.....soo does anyone know where or how to shorten the throttle cable ????
u can't shorten the cable, but u can try other cables. You have an si cable right? DPFI cables are huge.
i ran mine real low behind the engine, and then looped it back up. that cable can bend every which way and still function properly. Try adjusting it at the throttle body or using a different cable holder. i had a PR4 cable holder:
