I think you're right, at least I hopeI think the front lip will give the car a more balanced look with the wing. btw what issues did you have with your Tein coilovers?
It was a combination of two issues
1. Left rear coil just needed a height adjustment of 1/16"
2. I noticed that my rear wheels had different tires sizes, 205 compared to 225. Noticed the same on the front. I have a staggered set, so thinking nothing of it, I matched up the 225's to the rear and put the 205's in the front as they should be. This is when I started getting a thunking sound. As it turns out, the shop that mounted the tires didn't know it was a staggered set, and f**ked it up. One 6.5" wide tire had the 205, the other had the 225, and same with the 7.5" wide wheels. The wheels were originally mounted correctly, but when I saw the mismatching tires size, I swapped two out not realizing the tires were just mounted wrong. The difference in offset was enough to cause that noise over bumps (I have 15mm spacers up front and 25mm spacers in the rear).
Had the tires remounted correctly, and the issue went away.
