You do not NEED camber kits.
Status
Not open for further replies.
JohnS.
BANGARANG
This is a copy and paste from Honda-Tech. It's a good read. I took the quote tags off to make it easier to read. But I do NOT take credit for this information. The point of the following is that you don't NEED camber kits to prevent accelerated tire wear. He is not trying to argue you don't need camber kits in general. Of course different situations vary from each other.
Here is the link to the thread if some of you care to read any comments posted (which there are):
http://www.honda-tech.com/showthread.php?t=2614449
Just to be clear, I made this thread to disspell the myths perpetuated by magazines and other sources since the mid-1990's that a camber kit is REQUIRED to prevent excessive tire wear after a car is lowered. This is a flat-out LIE! Please read on to see why.
Well I guess this thread is long overdue, as I've had several requests to make a thread like this.
Despite the myths that have been perpetuated since the mid-90's, camber kits ARE NOT required to prevent uneven tire wear after lowering a Honda. Even the very first issue of Super Street magazine in 1996 talks about installed camber kits to prevent tire wear.
Here's what really happens. When you lower your Honda, especially those with double-wishbone suspension, the camber angle goes negative, but the front tires also toe out. That toe-out condition is what is important. Toe-out will destroy the inside edge of a tire MUCH faster than negative camber ever will, because the tire scrubs on the pavement as it rolls in a toe-out condition.
So the myth has been that you need a camber kit to bring the camber angle (non-adjustable on most Hondas) back to stock specs. So you install a kit, take the car to alignment shop, and *poof* no more tire wear. However, what really happened is that along with adjusting the camber, the shop also adjusted the toe. That toe adjustment is what REALLY saved your tires.
The truth of the matter is that you have made your car handle worse with straight-up zero camber (or close to it). It is also truth you can easily run -1.5, -2, -3, even close to -4 camber up front with very little tire wear issues. You just need to be sure to keep your alignment in check and rotate your tires every 5K miles or so. You should get an alignment at least once a year, or better twice a year if possible. All you need to do is get the toe adjusted back to stock specs. If the shop tries to sell you a camber kit, tell them no, just adjust the toe. If they say they can't do the alignment until you get a camber kit, then leave immediately and go to another shop because that is 100% COMPLETELY FALSE!
So let's talk about the "cons" of camber kits:
  1. Cost, plus the extra cost of alignments every time (could be $150 or more)
  2. Usually made of sub-par materials that rust, corrode, and seize up
  3. Greatly reduces suspension travel clearance, both UCA replacements and just the bolt-type kits
  4. Bolt-type kits are nearly impossible to keep straight and adjust correctly without throwing caster off
  5. UCA-replacement kits often use POS ball joints and have even more reduced clearance under the fender
  6. Likely to slip out of adjustment, requiring another expensive alignment
What are the "pros" of camber kits? Well you can add MORE negative camber than what you get from lowered suspension geometry alone, which can be good for track use. Other than that, I can't really think of anything.
One exception: A few relatively newer Honda models, such as the 96-00 Civic, the rear suspension has a pretty steep camber curve, and could benefit from slightly reducing the negative camber in the rear from what you get from a drop alone. I would recommend the replacement rear upper arm-type camber kits. Those use a turnbuckle-type adjustment that will not slip.
And now for some personal experience. I lowered my car back in early 2002 and had about -2* camber up front. I've been on various suspension setups since then with anywhere from -1.5* to -2.8* front camber and have NEVER used a camber kit. Since then I've driven about 175K miles, and I've only been through 5 or 6 sets of tires. I've always used V or W-rated summer tires, and they always last 30K-35K miles.
Now I do get a slight bit of inner wear, but I attribute that to my worn stock bushings that aren't keeping the toe in check like they should. I have all new bushings waiting to go in and I expect tire wear to be even less than before. But my tires do usually wear down past the wear bars before the inner edge shows any belts, so at that time it's time to replace the tires anyway.
I know there are many others on this site who can relate similar personal experiences. I'll let them chime in if they want.
Well that's about all I can think of to say. Hopefully this will help to dispel some of the myths. Hopefully I can help some people keep some extra money instead of wasting it all on camber kits and expensive alignments.
*edit* something else to add - lower profile tires will tend to wear a bit more on the inside edge with negative camber, even with proper alignment. I do get a bit more inner wear on my 205/45-16's than I did on my 195/55-15's or 205/50-15's. I would imagine 40-series tires would be worse. A taller sidewall can flex more, therefore more even pressure is maintained across the tread even with negative camber.
Puma
Has no filter
Can we PLEASE sticky this???? I'm so sick of seeing zomgneeedacamberkitbcithinkmycarisdumped!!!
TigBitties
Frame Bangin
definately sticky, i have one, but for cosmetic purposes
31dev31
Chillin' Canadian Member
Good info here!
Just adding in some information from my experience. My car is lowered 3.25 inches front and 3.5 rear (with coilovers) and never got an alignment or get a camber kit after, but I did check the toe on an alignment rack. I drive on 185/60/14 tires with 14x7" rims, and never had tire problems. It's been 1.5 years since lowering my car, and driven 50,000 KMs on the same tires, and yet no wear.
TigBitties
Frame Bangin
^same here, and i constantly check my tires for excessive tire wear. There isnt any. I got lucky though then. I still want to get one at some point
Puma
Has no filter
I have one, but only b/c I'm too low and even after numerous alignments, no dice. That and I refuse to raise it up. hehe
TigBitties
Frame Bangin
yeah i got one in the front, and its tucking some since its winter mode. i kinda need it once im that low. if you got wheel gap, you arent low
TigBitties
Frame Bangin
idk my degrees, never got an alignment, i put it all on in november and it is all perfect. no tire wear and drives straight. so i said screw it. Ill get one when i put it at spring summer height maybe.
JohnS.
BANGARANG
I need to get my car aligned again. My rear tires are feathering on the inside and my front tires have a decent amount of camber wear on the inside as well. Need to get a wheel bearing replaced first.
My car is getting all worn out :(. Gotta do timing belt, tensioner, water pump, seals, etc. too :(. Thankfully my friend does his own work and is doing it for me. He tore apart his H22 and built it on his own.
Puma
Has no filter
I raise it 1" for the winter, so re-align. Lower for warm months, re-align. PITA!!
TigBitties
Frame Bangin
Lol i put mine on in winter and only went lower. and plan on going even lower
Puma
Has no filter
I'm maxed out..down 5". I win! :P
TigBitties
Frame Bangin
if i maxed my skunks out, well i dont even know if thats possible. im tucked and got like 3 or 4 more inches to go. I dont even have that much ground clearance. hmmm i will win, just you wait, PA is a tough place for this
TigBitties
Frame Bangin
indeed it should so i stop posting on it
evilrilla2
This post has been circulating for years holmes.
I have a 96-00 model and the author is correct, I needed adjustment in the rear. I corrected it.
Status
