Originally Posted by evilrilla2
Originally Posted by JohnS.
I think you're confused... The author does not recommend camber kits for 96-00 civic's. He says they could benefit from one. He said he recommends a particular type if 96-00 owners do get one.
I bolded, underlined, and highlighted in red the keyword in the paragraph below of which you are talking about :
It It DOES need camber adjustment with certain drops and rims, I have pictures to prove it too! Before and After. I bought 17" rims with low profile tires, dropped my civic to the lowest possible position. All tires were NEW 100% thread. within months the rear had inner baldness. I freaked out and made a thread in July thinking I needed a camber kit:
http://www.clubcivic.com/board/showt...lrilla2+camber
I stumbled into the link that you also found. I did a DIY from a link that LowNSlow97 gave me. I placed about 5 washers if i remember correctly. Then I moved the rear tires to the front, the front tires were not bald. Up to date, 7 months later, my rear tires are not inner balded.
Hence, if I were to leave them as is, because it was RECOMEMENDED i didnt need it, my tires would have had wires sticking out from the inside, thus resulting into a tire pop.
For me, having 17" rims, this is correct:
One exception: A few relatively newer Honda models, such as the 96-00 Civic, the rear
suspension has a pretty steep camber curve, and WOULD DEFINITELY benefit from slightly reducing the negative camber in the rear from what you get from a drop alone. I would recommend the replacement rear upper arm-type camber kits. Those use a turnbuckle-type adjustment that will not slip.
All this is based on REAL life experience and If you want me to post the pictures to prove it, I will.
Posted from Clubcivic.com App for Android
