Finally some updates...
I've been working on cleaning and painting the trans.
Before:
After:
Only about 2/3 is done so far. The other side is still pretty black. I'll hopefully be able to finish that up in the next few days and start on the engine.
Since I changed to OBD2, I will be running the intake air temperature (IAT) sensor on the actual intake. This leaves a hole in the intake manifold runner where the OBD1 sensor would normally go. I made a custom block off plate to solve this problem.
This is a test fit. I need to find some better looking hardware and throw some Hondabond on there before tightening it down.
Also purchased quite the stash of HAMP Synergy filters. These should last a couple thousand miles...
Before:
After:
