could get two bolt and a two bolt bracket and you are set thenHey, when I get around to ordering swap parts, do I need the EKSTK 2, or 3 bolt timing side mount kit for the 92-95 b16a?
CHILD is correct
Awesome, thanks for the help guyscould get two bolt and a two bolt bracket and you are set then
looks good reed! maybe ill have to look into hmo if this teg engine ever dies on me
you will probably need a good impact for that crank pulley bolt though
Thanks for looking out man. I think I found one though. I'll let you know if the deal falls through.I may have one, bump this in the morning so I remember to check after work.
I highly recommend them. Closest you can come to a brand new motor, aside from purchasing it from Honda.looks good reed! maybe ill have to look into hmo if this teg engine ever dies on me
Thanks bro!Nice!
Don't you feel cool? HahahaThis is such old news...
Yeah, I was checking it out and it looks like they just unbolted the bottom portion. The studs are perfectly intact. I was also able to find a lower portion so I'm going to try it out. I'm pretty sure it'll work out.Oh now everyone thinks it's a great place to buy from lol. Don't be sore about the lower half of the header, most of them are cut at the flange making the bottom half unusable without welding anyway unless its a type R, they are typically treated like trash.
My old long block was solow mileage that i didn't bother with the oem maintenance pieces
Nice...
Thanks fellas!
Thanks man! Yeah its a pain. Luckily I got it loose today. Details soon.very nice man. and I feel your pain on breaking a tool on that damn crank pulley bolt
dont forget to change the tensioner and the spring for it awhile!Tomorrow, the timing belt and water pump.
Yes sir. I've got new OEM parts for both of those as well.dont forget to change the tensioner and the spring for it awhile!
Thanks dood!
