I've been really slowed down waiting on parts shipments to arrive. Over the weekend, I found some brief entertainment in pulling the rest of the front left suspension apart and stripping the steering knuckle. After the dramatic battle with all of the rear suspension fasteners, I was amazed when the upper control arm bolts simply backed out with a 2ft ratchet. Good thing, too--my impact gun would never fit in the tight access allowed in the engine bay.
Look at how amazingly clean this bolt is!
In a matter of 60 seconds, check out what's now missing?
Same story with the lower control arm--the impact gun zipped all the bolts out without issue.
Here are the remains on the floor. It's pretty much all scrap except for the steering knuckle.
Up next, pressing the hub and bearing out of the knuckle. I hear this is a very common issue, but the inner bearing race came out with the hub
Thankfully, I was able to drift it off the shaft with a cold chisel after heating it thoroughly with a torch. This was much less of a battle than I had anticipated.
Here's my setup for pressing the remains of the wheel bearing out. I had to load up the 20-ton press and then smack the knuckle with a hammer to finally break the rust free. What a pain. Even the snap ring preventing the bearing from coming out was rusted in place--I had to work it out with a hammer and chisel.
The dust shield was really getting in the way of decent support, so I ripped it off. Impact drivers are a beautiful thing for extracting rusty phillips-head cap screws.
The dust shield didn't quite make it. I have ordered a new pair of shields, fasteners and bearing snap rings and hope they arrive in time for the weekend. Here's how the bearing remains looked when they finally came out.
Here's the knuckle sans bearing.
Access to the balljoint with either the press or my balljoint removal tool was pretty poor…so I clamped the knuckle in a vice and just smacked the balljoint out with my 4lb hammer. No pictures there.
The final lingering issue with the knuckle was that both brake hose securing bolts snapped off flush when I tried to remove them. I drilled out the centre of the two bolts using left hand drill bits in three steps up to 9/64ths. Then I torched the knuckle and backed the bolt stumps out using left hand extractors. This required lots of patience, but I was successful. I'm practicing my rust-belt mechanic's skills on this project.
Drilled out.
On its way out.
That's really all I got accomplished. The replacement TruHart control arm arrived and so did the Hardrace bushing kit for the lower control arms. I'm still waiting on a) the front suspension hardware and strut assembly parts from Honda, b) my civic EX lower control arms to install the bushings into, c) my SKF wheel bearings and d) the dust shield parts. Hopefully, this thing will be ready for the alignment rack by the end of the upcoming weekend. I'm stoked to see how it drives now. Thanks for reading!
Drilled out.
On its way out.
