b00sted D's Sign in!
whtcivic93
www.mm-graphics.net
1993 Civic EX
D16z6
All stock bottom end
Garrett .42/.48 T3 @ 5psi
FMIC kit
Chipped and Tuned p28 using Crome
Engine being pulled next weekend for TT Rods, Vitara pistons.. 440cc injectors and retune, hello 15psi!
D16Y8-T
D16Y8
Turbonetic Turbo @ 7psi
Drag Manifold
Turbosmart wastegate
Vortech Blow off
Precision Turbo & Engine Front Mount Intercooler
Crane Hi6 Ignition
Precision 440cc Injectors
Chipped P28, Crome Tuned
AEM Fuel Pressure regulator
boosted94civic
d16z6 (stock)
td04 50 trim 5lbs boost
tial 38 wastegate
vortech fmu 12:1
hard pipes and jdm sport front mount
xs power boost controler
hks ssqbov
forcdincivic
Needs More Snail
dirtyD what intercooler piping did you use or did u just paint it black??
garrett t3/t4
450cc dsm injectors
tial 38mm wastegate
godspeed intercooler
hks style bov
afc neo hack
castiron manifold
custom d/p
apex n1 catback exhaust
watisjdm
Clit Commander
im gonna forget some stuff and i kno but future setup in a couple of months
Garrett GT3071R .63 a/r with 4" inlet turbo
Yonaka 24x9x3 Intercooler
y8 block sleeved with stock bore of 75mm
vitara pistons
eagle rods
cometic head gasket
acl race bearing
spoolin performance turbo manifold
tial 40mm wastegate
hks ssqv bov
rc 750cc injectors
chipped p28 on crome
3" downpipe and 3" exhaust
i kno theres alot more just dont feel like lookin and etc
should be around 400-450 when finished
CivicEX13
CC's Valve Cover Guy
edelbrock turbo kit on 8 psi
world electronics pbc-1 electronic boost controller
182 hp and 146 ft lbs at 8 psi
Chris.
Stickin' it to the man
yea i got one.....
D17A2
all stock motor and trans.
Dezod motorsports turbo kit
T3 super 60
stainless log manifold
TiAL 38mm wastegate
TiAL 50mm BOV
2.5" DP
innovative wideband
autometer 20psi boost guage
Greddy Emanage w/Greddy pressure sensor
Dezod plug and play harness
Dezod motorsports FMIC
Dezod motorsports intercooler piping
TurboXS manual boost controller
Golden Eagle vaccum manifold
218hp/198tq
soon to be upgrading the log manifold and intercooler next week and retune shortly after
EG Hatch
D15B7
STD Manifold
DSM 14B
DSM 1st Gen BOV
DSM 450cc w/ Honda Resistor Box
2 1/4" Exhaust
No name intercooler
K&N filter... that thing adds at least 100hp because it is K&N
Chipped P06 running crome... soon to be tuned
3 Layer headgasket
ARP headstuds
Home made boost controller
1Lowcoupe
wow.. this thread is old as hell. i'll post anyways.
D16z6 @ 10psi
Greddy turbo manifold
Greddy o2 housing
Greddy TD04H 15g
Greddy downpipe
Greddy charge pipes
Greddy blue box
BBK 62mm TB
AEM fuel rail
AEM fuel press. regulator
AEM wideband uego
Knock off SSQV
Edit: 28x7.5x2.5 bar & plate intercooler
2.5 inch charge pipes
3'' downpipe back exhaust
hi/lo boost electronic boost controller
joegould29
95 civic LX sedan
Stock D15B7
T3/T4 turbo
No name IC
Type s BOV
FP REG
Stock injecters
Full cat back 2.5in
tuned on crome
TiiM iiS l3eAsT
Scamming Piece Of s**t
1991 Honda Civic HB Std.
-=Engine=-
ReBuilt 1.6 Dohc ZC
SRP 75mm Pistons w/ SRP Rings
Eagle H Beam Rods w/ ARP Bolts
ARP Headstuds
HKS Bead HeadGasket
Brand New OEM -Timing Belt, Oil Pump, Water Pump, Main and Rod Bearings
Head Rebuilt w/ OEM parts and Hot Tanked
Stage 3 Clutch
8 lb Flywheel
NGK 2 Steps Colder BKR7E-11 Sparkplugs gapped @ .028
Magnacor Sparkplug Wires
Halfsize EG Aluminum Radiator
-=Turbo Setup=-
Garrett T3 .42/48 Turbo
Chipped PM6 ECU basemap w/ BRE
Custom HF TopMount Manifold
2.5" DP and Catback into fart can
450cc BlueTop Injectors
Jegs Oil Lines
CXRacing Intercooler
2.5" Intercooler Piping
Walbro 255LPH Fuelpump
Greddy Type S Bov
TunerToys Vacuum Manifold
Stock Map Sensor
1-3 gear
http://www.youtube.com/watch?v=OZzmOKWlztU
4-5 gear
http://www.youtube.com/watch?v=PaUAvKARSY8
Gonzo
Tin Foil Member
Current Set up:
Stock Internals
.57/.63 t3/t4 Turbo
FMIC
Cast Log Manifold
Custom 3” Downpipe to 2.5” Exhaust
38 mm Xspower Wastegate
7lb Fidanza Flywheel
Black top 450cc Mitsubishi Injectors
Tuned to 10 lbs On Crome Pro
LSD Steath Oil Line Kit
Walbro 255lph Fuel Pump
ARP Headstuds
Cometic Head gasket
NGK 8mm Plug wires
Autometer Phantom Boost Gauge
Going In When it gets warmer:
Balanced Z6 Block w/ Stock Head
Vitara 75.5 mm Pistons
Eagle “H” Beam Rods
Stock Crank
Fidanza 7lb Flywheel
XTD Stg 4 Racing Clutch
OBX Helical LSD
OBX Extended Wheel Studs
.57/.63 t3/t4 Turbo
FMIC
XS Power Mini-Ram Manifold
38mm Xspower Wastegate
ARP Headstuds
Cometic Head gasket
NGK 8mm Plug Wires
750cc RC Injectors
22” M/T Slicks
Tuned On ECtune
Goal For That Set up is 400 HP DD
