Cleared the code (there's just one being thrown) P0141 downstream o2 sensor, circuit heater malfunction, yadayada.. (tired of seeing this code.)Haha...Pull the CEL codes and write them down. Then drive the car until the CEL turns on and then pull the codes again. Post codes that repeat.
Test the battery and alternator.
Unplug the primary O2 sensor to see whether the engine runs better.
Have you tried adjusting the idle speed as per the service manual?
I do not have a multimeter but I will be going to a buddy's house tomorrow and he has one so we will check the battery. According to autozone's tester my battery was at 12.55 volts with the car off.When you turn the key from off to ON(II) (engine not running), does the charging system warning light (battery symbol) in the cluster turn on and stay on?
Do you have a multimeter to do battery and alternator tests?
For the O2 sensor test, drive the car until the problem begins. Then pull over, unplug the primary O2 sensor, and drive the car to see whether the problem stops or continues.
Thank you, will do. I'm about to go to work, so I will get on there and post about the charging system light.First check the charging system light.
You can buy an adequate digital multimeter for $4 from Harbor Freight Tools. You need a multimeter if you want to do your own car work.
Voltage tests of the alternator are done with the engine warmed up under no electrical load versus electrical load (headlights and A/C with blower on MAX). Post the voltage readings across the battery posts under these two conditions.
Never do this^ test. It's risky. The battery acts as a buffer to dampen voltage spikes from the alternator. When the battery is disconnected and the engine is running, the voltage spikes may damage sensitive electrical components, such as the ECU.Also, my friend wants to take off a battery terminal while the car is running to see if it runs off of the alternator? I've heard mixed reviews about this. Could this potentially harm any of my electrical components? If so, how? So I can explain to him. lol
There are also other possible causes.I also read online that if your radio whines when you rev the engine that that's a sign of a bad alternator. Mine does this, but only when I have something plugged up through the auxiliary input. Just thought it might be worth mentioning.
Hey dude. Don't worry about me. Are you okay?An unexpected hospital stay got in the way. Not taking your help for granted Ron!
Well, I can only imagine having so many people ignore your advice can get a little frustrating at times. LolHey dude. Don't worry about me. Are you okay?
Please don't worry about me. I'm not naive. If my tech advice gets through to 20% of the members I respond to, then I feel successful.Well, I can only imagine having so meany people ignore your advice can get a little frustrating at times. Lol
I'll have to check it out. I hope you're feeling better soon.But yeah I'm okay. Just recovering. It's a long story but I posted about it in the "what are you doing today" thread if you're interested.
Yeah. It sucked.
Thanks Ron, I appreciate it.Please don't worry about me. I'm no naive. If my tech advice gets through to 20% of the members I respond to, then I feel successful.
