Chaos's Christmas BuildUp
Status
Not open for further replies.
4doorcivic16
hmm maybe thats why my friends turbo made funny sounds or because it was a ebay one.
TiiM iiS l3eAsT
Scamming Piece Of s**t
i took off the pipe that goes from the turbo compressor and checked for oil and found nothing (good sign of not a blown bearing)....also i checked the turbo to see if it would spin more freely (since the turbo had just been sitting around for more than a year or 2) and yes it does......oil makes a big difference lol.....it spins so freely and clean now.....so im going to try to turn it up to 10psi today and see what it does =)
TiiM iiS l3eAsT
turned it up to 10psi and wow it pulls like a motha.....lol.....cant get the tires to break loose in a 2nd gear pull though so still not enough power for me lol......but its definately FASTER than b4......the turbo takes a sec to reach 10psi but once it does it pulls nicely !!! i also found my oil feed line has a leak where it connects into the turbo......i guess it got overtightened and now oil will spew all over the hood and on the right side of the engine bay after a hard pull......i stuck more tephlon tape and tightened as much as i can get it but it still spews a little bit.......so i plan on either buying another fitting for the turbo.....or a new line....i guess ill find out which one is stripped out tomorrow once i check it......internal wastegate works pretty good though....no boost spike or creep so thats good.....just a solid 10psi
petercross
4th Gen Civic Curator
well..isnt this the first person with good grammar...jus kidding...you can google up wire tucks....they have DIY's on there that are really good for wire tucks....i did a small one on the passenger side...looks cleaner...but still needs to be better! anywas man, just googling is your best bet..
hey chaos, what brand for pistons and rods would you think to be the best for ls?
Alright!
Thanks a lot man! Really getting to enjoy this thread!
TiiM iiS l3eAsT
well i replaced the line with a spare braided oil line and it seems to be doing fine......i also put on my bumper finally so ill have pics later
TiiM iiS l3eAsT
pics:
and ofcourse the engine :
also made a b4 and after pic of my car lol
heres it about a month after i bought it (around 3 yrs ago):
and heres it today:
TiiM iiS l3eAsT
nope....found my top radiator hose had a leak so i replaced that......so now it doesnt loose antifreeze anymore......if im on the highway it does fine , no overheating and such.....but once i come to a stop it will slowly overheat....so i try not to drive it for a long time.....no long trips and such......so for now its just driven around town .......
Steven.
Formally Green 91
you should either wrap the turbo down pipe, or high temp paint it.
btw, stock water temp gauges are known to be inaccurate
TiiM iiS l3eAsT
yea ill probably heat wrap the downpipe and manifold.....im thinking about buying a aftermarket temp gauge that way i can have a accurate reading
Steven.
Formally Green 91
get a good EGT and good water temp gauge
kyle10182
NA is Best
my integra does the same thing every couple of months. then i fill the cooling system and bleed the air out. problem solved. im not sure where its leaking out.
im guessing you havent bleed the coolant and still have an air pocket somewhere.
TiiM iiS l3eAsT
could be honestly....i guess ill try bleeding it and see what happens.....also figured out my radiator fan relay is bad so the radiator fan hasnt been kicking on.....maybe that could also be the problem.....
Destroy
So I see that you finally got it dynoed? Seems like a lot of torque for 10psi, did you already post up your sheet?
slowcivic E G
bla bla bla
that will definitely contribute to overheating while you're not moving.
TiiM iiS l3eAsT
got some vids of me racing my buddys 03 civic lx stick.....
he started in 1rst..... i started in 2nd......started around 25....i stopped around 70-80
http://www.youtube.com/watch?v=c7qkSZPbyq0
highway roll at 60 were both in 3rd.....for some reason my car takes a second to go.....idk it runs like s**t until its in boost lol.....and i also couldnt find 4th which is why it takes me a sec to catch him....i stop at around 115
http://www.youtube.com/watch?v=0ohIdSCGIVQ
Status
