That would require not being lazy, that's a no fly zone for me lol
You could fab parts too![]()
Yeah it's a manual rack. Power steering is being deleted so I wanted a proper rack instead of looping lines.word. that steering rack, is that manual?
Right on! It is Monday, and I bought a bunch of ish!It's Monday....let's buy some s***
Mugen
Asr
More asr
Works bell
Apex'i
Oem Honda
Ktuned
Think I'm gonna save for a tune
yeah, i'm dreading the day I finally get body work and paint done.
Mostly OEM Honda stuff for me. About to pull the trigger on paint and dent repair, but it's tough, since that's the single biggest cost for me, aside from an engine swap.
I feel like shooting myself in the face over the indecision going on in my head... "Do I keep it silver? Do I change colors? What color would I change to? Do I really want to change colors or keep it sliver?" over and over and over again.yeah, i'm dreading the day I finally get body work and paint done.![]()
I don't know about chaging the VIN in kmanager, never looked into it. As far as passing, you can have your engine harness wired up with an OBD connection so that you can plug in like normal. No CEL codes typically means a pass. I don't get the whole VIN issue, because if someone has a failed ECU and purchased a new one even from a dealer, it's not going to come with your original VIN number attatched to it.I can't find any definitive answers by searching, but have you checked into whether your swap will pass emissions testing, legally? If I had decided to buy a 92-95 hatch, it would pass on a dyno with no problem.... but I'll have to use the pesky OBD plug for my 98.
I'm also curious how much access to the ECU Hondata gives you, because I'll need to erase the VIN# off the ECU, because Texas has updated the inspection machines to look for and pull a VIN# from the engine ECU's to make sure someone isn't plugging in one car to pass another.
I can't speak for Honda/Acura, but at Toyota/Lexus for new or reprogrammed ecu's VIN# gets programmed to the vehicle for anything '04 and newer... throws a trouble code for mismatched vin or no vin and sets the check engine light if it's not set.... '06 and newer gets substantially more complicated.I don't know about chaging the VIN in kmanager, never looked into it. As far as passing, you can have your engine harness wired up with an OBD connection so that you can plug in like normal. No CEL codes typically means a pass. I don't get the whole VIN issue, because if someone has a failed ECU and purchased a new one even from a dealer, it's not going to come with your original VIN number attatched to it.
7 days until swap time. Got more parts on the way. Some new bits and piecesNot a bad way to spend some $$$ Looking good Cant wait for the #s on The K
