If you are going with a thicker rear swaybar you need to add some type of reinforcement or it will tear the rear up. I suggest you get the ASR brace and the ES D brackets and bushing.SiRcivic27 said:Anyone?
yes it will fit if it comes with all the mounting hardware. And yes i believe you can keep the skunk2 tie bar.SiRcivic27 said:that wasnt my question, will the sway bars fit without the ASR brace? I have a skunk2 tie bar and I really dont want to go through the trouble of selling it and lossing more money on s**t because I have a hard enough problem as it is trying to sell parts I dont need anymore after I boosted..
That sucks man about the skunk2. You could run that with a rear sway although, like everyone else has said on here and on hondatech and everywhere else I've read, you should def. upgrade to the asr or atleast the beaks kit if your gonna get something bigger than a 13mm rear sway. You def. dont wanta have to worry about getting your subframe worked on/welded/ etc... I've had enough issues w/ a lca bolt that sheared off and had to be drilled out.that wasnt my question, will the sway bars fit without the ASR brace? I have a skunk2 tie bar and I really dont want to go through the trouble of selling it and lossing more money on s**t because I have a hard enough problem as it is trying to sell parts I dont need anymore after I boosted..
damn i want to see thisBlackHope121 said:lemme find that pic of what a ripped out subframe looks like
ASR is strong enough. Its only looks if you want to put one back in. Its not going to make any difference either way.Nice writeup! I'll definitely be using this in the future. I noticed that you didn't put your tie bar back in. Is that b/c the sway bar replaces it or because the asr brace is solid enough?
Cool. Thanks for the info. The reason I asked was because I have a brand new skunk2 tie bar that I purchased got along with my suspension upgrade but I didn't end up installing it. I guess I might sell it as wellASR is strong enough. Its only looks if you want to put one back in. Its not going to make any difference either way.
yup perfect! thanks bro!Great how to i just installed my asr brace and swaybar today thread helped out alot.
