DUMPED! after a median jump... (56k, no)
PhntmSk8r
H23VTEC
Well monday night (april 16th) and into tuesday morning i was out and about at a friends house.
I left his house around 1am and was going to head home, pouring rain, went to merge onto the highway through this loop around to the merging lane, and i hit a pot hole car bounced, started to understeer and i jumped up over a curb, slid across a median and dropped off the other side before comming to a rest. I had all season tires and probably 75% tread, and still happend. Shitty suspension.
I wasnt pushing my car, wasnt driving too fast for the conditions, just doing about 20-25 into this big loop around corner, and the car just decided it didnt wanna turn with it. Once it started to understeer i let off the gas hoping it would pull out of it, but it kept sliding to i paniced and hit the brakes.
Heres the results.
Previous ride height:
Post Curb hop ride height:
Spent 3 hours on the side of the road in the pouring rain trying to get everything straightened out, finally get it going, set the car back down on the ground... find out my half shaft is broke, drivers CV is broke, limped the car home 20ish miles at 10mph... 2 hour drive, usually a 20 minute drive.
Heres recent pics of where the car currently sits:
Tire that hit the curb:
Oil Pan/Header:
Only real body damage:
Hasport Axle:
I started ordering parts Friday. So far ive ordered:
Ksport Coilover suspension
Ksport Rear Lower Control arms
Front Lower Ball Joints (L&R)
Front Wheel Bearings (L&R)
Inner/Outer tie rods (L&R)
Oil pan/Gasket
Ordering soon:
Ingalls Front A-Arm Camber Kit (adjustable ball joint)
Ingalls Rear Camber Kit
Corsport Stainless Brak Lines (front)
Corsport Stainless Clutch Line
Skunk 2 Extended studs
Skunk 2 Open Ended lug nuts
Spun SPK-9 16x7 Black
BFG GForce KDW NT 205/45/16
PENDING:
Hot Shots 4-1 Racing Header
UPDATE:
Everything below is ordered, things with (R) beside them, i have. (S) for being shipped
Ksport Coilover suspension --- (S)
Ksport Rear Lower Control arms --- (S)
Front Lower Ball Joints (L&R) --- (R)
Front Wheel Bearings (L&R) --- (R)
Inner/Outer tie rods (L&R) --- (R)
Oil pan/Gasket --- (R)
Ingalls Front A-Arm Camber Kit (adjustable ball joint) --- (R)
Ingalls Rear Camber Kit --- (S)
Corsport Stainless Brak Lines (front) --- (S)
Corsport Stainless Brak Lines (rear) --- (S)
Corsport Stainless Clutch Line --- (S)
Skunk 2 Extended studs --- (R)
Skunk 2 Open Ended lug nuts --- (R)
Spun SPK-9 16x7 Black --- (S)
BFG GForce KDW NT 205/45/16 --- (S)
Also going to pickup some OEM mudgaurds, and i still need to order my axles.
Genuine Rolla
Its PETEY PETE, y0!
dang bro...freaking huge hole in the tire. glad that you're OK tho.
w00t for new parts.
defvayne
Set This World On Blaze!!
ouch man hope the shock is still good.
hkt03
shootin' sparks on i290..
didnt you just fix up your car or was that someone else?
glad you're ok though :thumbs up
aaren99
Glad to see your ok and getting it back together in a snap.
SiRcivic27
that sucks but at least you could fix it, I have a b-series 4-2-1 DC header that needs a new home now that I'm boosted, its got about 5000 miles on it and a new O2 sensor went in when I put the header on and it comes with the header, search the classifieds if you're interested. its under B16 Parts.
Genuine Rolla
Its PETEY PETE, y0!
He's got an H22 man, not a b-series.
Melt
wont do any good .... hes got the h double deuce :cool:
Road Pirate
Member
good god man!!!
now i see what you meant by 'i f**ked up my ride'
hope it goes back together well
Billy.
Has returned ;-)
wow that looks painful, glad ur OK tho, bump for new parts!
slowcivic E G
bla bla bla
that really sucks, but its good that the body damage wasnt horrible, when i was reading what happen i was expecting nasty pics, hope you get it back together soon.
PhntmSk8r
H23VTEC
thanks guys
most of the parts are already ordered so it should go back togther fine :D
All 4 struts are blow so theyre going to be making a new home in the dumpster behind my work...
mienboiracer209
:word:
but important thing is you're okay...the drive home must've sucked!!
Stocksucks
Shitty deal eh? I was the one that stood in the pooring rain right along with Nate! Horrible situation. Should have parked it at my house man and saved your axle. s**t happens though. Time for UPGRADES =) Can't wait to see it all back together bro! If I ever get a day off I'll help you out.
Suanico
f**k! i was racing some ls hatch in my old car and i hit a speed bump doing 100, have it on video too and my s**t wasn't 1/2 as bad as your man, good thing you know what your doing or some shop could have raped you on labor
SiRcivic27
never mind the, I didnt look to closely... that would explain the hasport axles :smackself
