Go-autoworks says their manifold is only ac compatible with 5 bolt style discharge. I had this crazy notion of keeping ac on mine but I currently have a 4bolt setup. Was seeing if yours was 4 bolt and what the exact issues were with that combo.
i will try to shorten the length of pipe before the bend and see if it will fit then, if not i will try to flip it around but i feel that it will be to close to the head then?What if you turn the wastegate around to point the other way
Sent from my VS930 4G using Tapatalk
i already wrote them and they said it could be a different turbine houseing because i guess garrett uses like 5 different 5 bolt housings. they are paying shipping and i just have to send in my turbine housing with the downpipe, only thing is they ship through fed ex and i live in a small town with no fedex so the closest fedex is 80 miles. i asked if they pick up at home and all he said was that i would have to give it to a driverTell go-autoworks to make you another one
As for the WG, good luck. Either you're flipping it around and snaking the pipe down the compressor side, or relocating it which will probably mess with how it operates in some fashion.
Had this issue when I switched from a tubular manifold to a cast iron log-style. Had to trim a section of the hood skeleton out to get it to fit, but it did eventually clear it.Nice Nice. Hopefully that wastegate isn't too high because my cousin had a cast iron manifold on his car with a Tial and it hit the hood a bit.
That manifold isn't AC compatible, regardless of what they say. The ones that are, have the wastegate bung between the runners for cylinders 1 and 3 (first two cylinders looking at the manifold head-on). It's also clocked at an angle that allows the dump tube to jut down toward the downpipe.Tell go-autoworks to make you another one
it might just be me but i didnt understand what you were trying to say here?Speed factory makes a 3-1 ac ic rad one peice set up for ~1g it's all hand made and would work good in your build
