well i drilled some new holes in my ac condenser bracket to pull the top toward the core support, then i wrapped the old bracket for the suction hose around the suction and discharge and bolted it together which pulled the suction hose about 5/8 of an inch off my dump tube.now i shouldnt get the heat transfer affect like a heatsink but i still have to work on the radiant heat coming off the dump tube.
my solution that i think will work is make a custom clocking flange at work
i believe the top hose is the inlet for the radiator so i shouldnt have to worry about heating the coolant, i just have to make sure when i make a new dump it doesnt touch the upper hose. i plan on dumping right in front of the passenger side tranny mount or maybe curve it under and dump a little further back.
cant tell much in this but you see where im routing the dump hopefully
Got my flange made, had to countersink the bolt holes to mount the flange to the manifold
well i got my dump tube made, im really happy with the way it all came together now hopefully this helps cool down my bay a little bit. i also reinstalled my turbo blanket but its a little big so im not sure how much help it will be
tacking together the pie cuts i made with a cutoff wheel and my grinder
all welded together
painted and wrapped, i have some new titanium wrap coming so i will rewrap it here in a few days
