Gauge cluster and climate control lights
dethseeker90
Red looks really good aha. Just depends on your taste. I'm about to do red for my sisters 98 accord. For some reason. Stock yellowish white lights don't work for her after she saw mine aha. Just follow all the steps and u should be good. Remember they r reverse polarity bulbs so if they don't work pull it out and turn en 180 degrees and go back in. I know If u do the climates wrong and put em in reverse they'll light up when lights aren't on and turn off when lights r turned on. Kind of weird how it works but that's the way it is. Best of luck to you on the red.
eh2manny
That IS weird haha. As soon as I find the bulbs I'll switch them out. Oh and I pm'd u about my so cal post haha
Furbyxv
Yeah, just depends on the model. 92-95 gauge clusters are different. Hatchback CXs and DXs have speedo but no tach. (some do have a tach) The Special Editions in Canada at least have both a tach on the CX and DX models. The Si hatch obviously has the tach. The coupes are a different story, the EX and SE both have tachs (manual and auto) and the Si obviously has a tach. (both for manual and auto)
Hope that helps a bit.
Yea my hatch is from Canada, the tach goes up to 10k which is weird cause all the ej1's and 4 doors go up to 9k. But the ej1's and the Canadian Si hatch has the same engine as an ej1 (d16z6)
durgo
What Luminous Intensity did you buy? are they bright enough? in the pic the gauges dont look evenly lit, are they? Thanks..
Ethan98civ
i didnt even know there was a ash try light???? my friend just did the LED LIGHT STRIPS! looks rlly clean in person!!!!! im just bout to get some but what im doing is... 3 in the cluster ,1 for air controls, 3 under dash where i can switch them on/off whn i like or dim them mayb one in trunck ciz its so dark . might do some under the seats but not to sure so im getting 2 extras
