Ok it seems that everyone is against the h22..... what I was going to do originally was to swap the b16 and mod it to get it faster but then this guy told me about the b18 and it is way more torque then the b16 and you'll start off at 15 flat instead of 15.7 with the b16 and its only a couple hundred more..... so I did all the research like a did with the b16 and everything i would need... then this other guy told me those engines are slow compared to the h22... with the h22 in your car you'll be running 13.8 with nothing done to it.... well I knew this couldn't be that great of a swap because if it was everyone would be doing it the engine was so cheap...... but there ended up being all these problems you run into with this swap... so i'm back at zero again.... and i'm stuck on which engine to get.... my goal is to run low 13's on street tires and 12's with slick..... and most importantly I want a RELIABLE car.... i'd perfer to go N/A but if turbo or supercharger is a must i'll do that as long as it won't mess up my engine... please post your opinions on which engine will get me to low 13's the quickest, easiest, cheapest, and most RELIABLE <- most important... Thanks for all your help....
-I DO NOT WANT TO KEEP MY STOCK ENGINE PLEASE NOBODY SAY TURBO IT
