redsidriver2
the B18c1 is also great for supercharged aplications fully built u can run about 11 or 12 psi from it and get great results http://honda-tech.com/zerothread?id=816770
what happened to this "I DO NOT WANT TO KEEP MY STOCK ENGINE PLEASE NOBODY SAY TURBO IT"edhgreatone said:haha this is so old... i am not even doing any of this... i'm getting a greddy turbo for my car and it will be faster then any of these swaps!
well motor swaps aren't what I call "reliable". Just turbocharge it.edhgreatone said:Ok it seems that everyone is against the h22..... what I was going to do originally was to swap the b16 and mod it to get it faster but then this guy told me about the b18 and it is way more torque then the b16 and you'll start off at 15 flat instead of 15.7 with the b16 and its only a couple hundred more..... so I did all the research like a did with the b16 and everything i would need... then this other guy told me those engines are slow compared to the h22... with the h22 in your car you'll be running 13.8 with nothing done to it.... well I knew this couldn't be that great of a swap because if it was everyone would be doing it the engine was so cheap...... but there ended up being all these problems you run into with this swap... so i'm back at zero again.... and i'm stuck on which engine to get.... my goal is to run low 13's on street tires and 12's with slick..... and most importantly I want a RELIABLE car.... i'd perfer to go N/A but if turbo or supercharger is a must i'll do that as long as it won't mess up my engine... please post your opinions on which engine will get me to low 13's the quickest, easiest, cheapest, and most RELIABLE <- most important... Thanks for all your help....
-I DO NOT WANT TO KEEP MY STOCK ENGINE PLEASE NOBODY SAY TURBO IT
Are you serious? Why would turboing be any more reliable then a swap?illicon2003 said:well motor swaps aren't what I call "reliable". Just turbocharge it.
There is a place here called "Velocity Trends", they claim to be building 11 sec. SOHC N/A engines.......that are safe enough for daily driving....regardless if it is true or not, I'd give them a call or visit their website...Hereedhgreatone said:does anybody know if a b16 can run 13's with out turbo or supercharger? would it be more money over to make a b16 run 13's or a b18???
