hey gabe .. that s**t is tight .. im not a wiring genius either .. you think you could get more pictures ? i cant tell everywhere you are groudning too .. but then again im a dubmass ...
That's what the green circles are for. I'll take some more pictures tonight or tomorrow...sit tight...I'm gonna change a few things up first too.RiceburnerRyan said:hey gabe .. that s**t is tight .. im not a wiring genius either .. you think you could get more pictures ? i cant tell everywhere you are groudning too .. but then again im a dubmass ...
I'm pretty sure that's been covered previously in the thread, I couldn't tell you because I got a kit and it is real high quality with gold plated connectors(jdm).bad6as said:any advice on what wire to buy and how many feet i should buy. im gonna do this tomorrow
gained when replacing stock grounds in thier orginal placement:do you all think this made you faster?
i'm sorry but i wanna clarify daisy chaining. do you mean every single ground point is hooked up to the battery? (bat to head, bat to trans, bat to intake, bat to alt, etc) or do you mean you connect them all to each other and none get connected to the actual body. haha do you know what i mean?green said:gained when daisy chaining them to one central location (neg battery ground)
Mahlmann said:i'm sorry but i wanna clarify daisy chaining. do you mean every single ground point is hooked up to the battery? (bat to head, bat to trans, bat to intake, bat to alt, etc) or do you mean you connect them all to each other and none get connected to the actual body. haha do you know what i mean?
Correct...start at the negative (-) battery terminal.WardsWarrior said:Yeah I'm confused on the term daisy chaining. I think by looking at the diagram it means connecting all the cables together by the terminals, so they're stacked up on one another. And it runs that way back ot the battery where the chain ends? But is there a certain place where it should begin lol (i.e. battery)?
Is this correct.
Did you ever replace the ground to your neg battery terminal, from the pic it doesn't look like you did, and why are some of your cables red and some black? Nice job eitherway, looks clean.gabebauman said:Correct...start at the negative (-) battery terminal.
I used 8 gauge wire and the 8 gauge ring connectors came in a packs of two, one red and one black (got the stuff from Radio Shack)WardsWarrior said:Did you ever replace the ground to your neg battery terminal, from the pic it doesn't look like you did, and why are some of your cables red and some black? Nice job eitherway, looks clean.
Also is there a specific gauge of wire you should use when redoing the neg batt terminal ground?
