The type of wire you use is important. Don't just use any type of wire. The bigger the wire the better and use good terminals....gold plated is better than discount auto terminals. I used 4 gauge Rockford oxygen free grounding wire and even replaced both the positive and negative battery terminal connectors. I took out all of the factory ground wires and replaced them with the 4 gauge wire. I connected the tranny to the negative terminal dirrectly since the terminal mount had two 4 gauge outputs. Then I went from the tranny to the throttle body, from there to the alternator, and from there to the power steering mount. Then the power steering mount goes to the frame of the car, this was one of the factory wire mounting locations. Wiring in a series like this is the best way to do a grounding kit. Make sure where the connections are to the body that all of the paint on the frame is removed down to the bare mettal, this insures a solid ground. The electrical system in a car actually runs from the negative to the positive, this is why a good size ground wire for any electrical component is necesary. Use oxygen free wires cause this will resist corrosion which will slow down the elctrical flow through the wires. It is also a good idea to not only crimp the wires, a bad crimp/connection can cause a voltage drop of 1 volt, but also solder the wire to the connector. If done right you should notice an improved throttle responce, smoother idle, and smoother overall engine performance. I would show you pics, but mine looks just like Gabe's pretty much......go figure. lol
