yup its running preety lean.all spark plugs have white tips..
and i finally got the screw off,and in the beginning the hole is big but about 1/16-1/4 in the hole,it gets small all the way through. i guess its still good then right since the hole then open all the way through?and now you think the car will run better with the screw off?should i buy new plugs?
btw i tried to start up the car with the screw of the missing link.but the car wont even idle properlly.its like falling sputtering/bogging.it wont even idle now.and on the boost guage its in vacuum already at 10.so i screw back the screw then it idle fine again.what does this mean now?should i just leave the screw on?
You can leave the screw on and just drive regularly until you get a tune, which should be as soon as you can. That hole is too big. Normally it's pretty small that the back of a needle can barely fit in...even in the pics I can tell it's too big so now maybe too much Air is getting out and it could be running rich.
tune.i should just buy a p28,get it chipped and dynoed?i should be able to use my stock injectors,fuel pump right?since im not planning to go over 220hp and im only on 6lbs.ill probablly push it to 8lbs though
