well i think they do becouse when i had my mitsubishi eclipse (ok honda guys dont kill me) i went throw 3 motors with a FRAM when i would pull it off the insides would be sucked to the top so i think they suck[/B]
Hello,
I am the technical manager for FRAM. What happened to you has happened at least once to anyone who ever changes thier own oil. The old "O" ring sticks to the block from heat. You always need to make sure it is not stuck on the block when removing the old filter. And, no FRAM filters do not "suck", they filter oil at 96% efficiency, in fact, they are original equipment on factory Honda's. Look at the blue honda filter, its made by Honeywell, parent company of FRAM and is nearly identical to our Tough Guard filter inside. I am happy to answer and filtration, spak plug and ignition or coolant/cooling system questions you may have. Have a great day
Thanks man. Yeah it's a daily so keeping it running is the priority. It does need tires, so a wheel/tire combo is next on the list. I'd love to see some pics of yours.Good to see your starting with the right parts and not just slinging money at wheels and coilovers before its in good running order.
I used to have a coup in exactly the same colour as that, only it was a right hand drive as its a uk spec.
Ill chuck up a couple of pics if you like.
Keep it up. Barney.
Hehe me neither.very nice coupe man. the looked very nice after that pressure wash. cant wait to see it with wheels and drop.
A self tapping screw will fix that right up. Its a very common problem with this generation. Theres a rubber piece in the wheel well thats supposed to channel water out, but it hold it in and rust out everything. Hope i helped!This happened about a week ago. Really not sure how or why. The mounting tab on my rear bumper seems to have broken off. It won't stay on.
I have some ideas on how I might fix it (Glue) but I'm looking for better suggestions. Anyone?
i had the same problem when i went to smog my car, but then again the california regs are the stricktest in the country you might wanna bring your timing light with you so you could retard your timming to the farthest point allowed... i went to autozone and bought this liquid that you put in your gas tank to help with the smog... drove it around and let the gas go to empty and then refilled it w/ 93 octane and also some lucas oil fuel treatment.... before i retested i let my car idle for about 30 minutes and drove it around for another 30 minutes to get the cat REAL hot !!! when i retested, i passed with flying colors hope this helps....Yeah so I post a lot of random updates in this thread. Keeps me motivated to continue working on the car.
I took her out for an emissions inspection Tuesday. Here's the result...
This sucks. Check out the legal limit compared to where I am. I guess the first thing I'm going to have to do is check the timing.
Really diggin your ride. I WANT DETAILS! Very classy.Cheers dude. I may put up a thread. ill see.
The busiest UK honda civic forum is civiclife.net join up and have a look around.... tell them Civic_Boz sent you!
Uk scene is getting better and better all the time.
