almost forgot how annoying those AN fitting are to put together.... took me few hrs of really really struggling to get that 90 fitting on the new line.... the black one is slightly different then the red/blue ones. the red/blue ones goes on with less struggle. i'll take another picture of the oil drain line. it still some how get a dip before getting into the oil pan this might cause oiling issue down the line where the oil might back up into the turbo and causing it to smoke alittle.. this is when i really wish i had another 90 would solve all my line problem.
what sucks even more is that if i had those dual core aluminum radiators which is a bit bigger in size i would have less space. no before i can go wit the up pipe i would have to make something work for heavy rainy days where the car has to be parked for a while.. but if those stock radiator mount brackets wasn't at that spot i would probalby have much better time doing a traditional route to the back.
yep now this whole downpipe situation is still getting to me its a really tight space for traditional route or bumper exit. still have somewhat of a decent space for it. hood exit is the only setup where it doesn't interfere with anything at all and wouldn't need to modifiy to make space. if i had known this issue with bottom mounts/ ramhorns, i woulda went with top mount stupid me... shoulda went with topmount manifold all this space issue won't be so much of a problem....my friend suggested using EF radiators since they can sit in that space between stock radiator location and intercooler. but its full width....I miss my boosted Civic, it was so much fun to drive lol.
I'd get whatever clearance you can, that pan is pretty low! I only got as low as a flat downpipe
