Need a short throw shifter that's more than just the stick
ocbasbalburg
it's just more fun to drive with a shorter shift length. And yes, APC is s**t, and i wouldn't buy anything else from them, but the short shifter i bought works very very good. Why spend an extra $50 for the same piece of metal/aluminum
skinnyjdm
Always bet on black
Originally posted by Beelzebubba
1: Remove APC parts
2: Burn, smash, and or otherwise destroy them immediately. They are poorly made and easy to break.
3: If you ever get the idea that buying APC is ok, punch yourself in the head till that idea goes away.
4: Send money you would have wasted on APC products to my paypal account.
Remember, you can't spell crap without APC
:laugh: :haha: :hitlol:
That's really funny
SDEKSi
It doesn't matter all short shifters will do it, u'll either have to have the piece that is rubbing against the exhaust cut off or somehow moved to the side...The same thing happened when I installed a DC ss on my 97 dx and on my Si...nothing u can do but cut it off or move it...
sidious_14
All that syncro stuff is stupid bs. Get a short throw man, youll be happy with it.
mugen_tuned
4G63-T
remove your heat shield and rap the area near the shifter with heat thermal rap!
anfrey
OG スバリスト
also bend the hangers for ur exhaust.
lj17
vsmc #7 cccc #169
i just wanted to know what exhausts you people have. stock? aftermarket? what kind? i could see if you had big ass exhaust piping the shifter would hit, but does it hit the stock too? just asking because i might get a short shifter and i have an apex n1 catback. i was going to get the skunk2 if i get one. i figured it would probably hit the exhaust from all the threads i have read on this. is the best solution to just remove the 2 inch long (guess) counterweight piece? is that the only piece that really hits the exhaust? if you do remove it, how does it affect shifting/feel? :what:
chimchim
iVTEC, do you?
I have a stock exhaust and the short shifter causes the linkage fork's counter weight to bang my stock exhaust. Removing the heat shield isn't enough.
So... as far as lowering the exhaust hangers go, how do you do this? Buy longer rubber hangers? If so, so I have to do this to the entire length of the exhaust (multiple hangers) or is there enough play to do just one? Or are you talking about bending the hook rods that the hangers mount on?
lj17
vsmc #7 cccc #169
i would probably rather cut off the couterweight piece than bend the exhaust hangers or move the exhaust, if removing it won't really affect shifting that much. i'm not sure about this though- can anyone who has removed the counterweight inform us?
if you would rather bend the hangers, then good luck, and let us know how it goes. i wouldn't prefer it, but everyone has their own ideas/preferences
anfrey
OG スバリスト
i'd rather screw with the exhaust than mess with something that's an integral part of driving
lj17
vsmc #7 cccc #169
maybe so, but i have no problem with and it would be fairy easy for me to remove the couterwheight. if it dosen't really affect the shifting/feel that much, i would rather get rid of it so i would never have to worry about it hitting the exhaust.
anfrey
OG スバリスト
in that case, go for it... and if it doesn't work as u want, just pick up another shifter
lj17
vsmc #7 cccc #169
its not the shifter that would be cut, its the shift linkage.
chimchim
iVTEC, do you?
Yeah, the counter weight is on the shift linkage. If you have welding tools to cut off the weight, then I don't see why you wouldn't use the same welder to put it back on a little higher. You'll lose a little mechanical advantage for the counter weight, but it'll be a lot better than no weight at all.
Or, weld cut the counter weight off, then mount some weights on to the shift linkage bar clamps or something.
Hey... let's think about this for a sec... the counter weight actually acts AGAINST your hand shifting. This probably gives it a more solid feel. Taking the weight off should increase the mechanical leverage your hand has way up there on the knob and make shifting feel LOOSER or less resistive....... yeah, keep the weights on. But move em.
More trouble than it's worth. I'm sticking with my stockie and just enjoying the grip and feel of my shift knob. I wonder if polyurethane shift bushings would be worth it to make it feel more precise and less mushy.
lj17
vsmc #7 cccc #169
what you said makes sense i guess. i was just hoping to hear from SDEKSi, to see if he cut the weight off or if he relocated it. i was wondering how his shifting was affected. i have a set of torches i could cut it off with, and could have my dad weld it, but i am not going to doing anything yet. i bet poly bushing would stiffen thing up. i'm going to get a set before my shifter "project" is all said and done. there cheap- like $10. just give 'em a try
ocbasbalburg
on my car and my friends Si, we had no problem with any sort of touching or rubbing of the shifter, so I find this all wierd????
lj17
vsmc #7 cccc #169
what kind of shifters do you two have?
ocbasbalburg
I have the APC (I know, but hey it works for now) and my friend's Si has a DC in it
lj17
vsmc #7 cccc #169
and neither hit anywhere? do you have stock exhausts or catbacks?
ocbasbalburg
stock exhausts, where does yours hit? Near the header, behing the cat??? No hitting anywhere
