Use this pic as reference as what the plugs are called and how their numbered. I want you to ohm out the signal wire from each sensor to make sure your plugged in the correct sensor. Go from the jumper harness at the ecu pin and ring out on the motor side.
So basically put your meter on ohm tone (beep with continuity) leave 1 lead on the ecu harness then touch all 3 (1 at a time) for the tps and map sensor then 2 on the iac.
D17 is for the map sensor
D11 for the tps
A9 for the iac.
If you dont get a ring from the plugs check the ones hanging under the intake.
Sent from my boujea ass phone
