no i dont know anyone with a honda :/Do you have any buddies with an obd1 honda that will let you try their ecu? The fact you have multiple clips unplugged and no cel is concerning.
Sent from my boujea ass phone
I will be sourcing a harness. Now what EXACTLY do i need? what year what trim etc?Harness yes ecu no.. now we have codes to go off were gettin somewhere..
3 map sensor
6 coolant temp
7 throttle angle
10 intake air sensor
14 electronuc air control
That sums up what we were thinking all along. Look at the dizzy plug is it 1 plug or 2? If you have a boneyard close where you can get a harness that would prob be easier then unmuffin what you have goin on there.
See thats what i dont understand car is a 1996 which is obd2. Original owner swears the engine was a 2000 acura LS engine (wouldnt that be obd2?). I believe you stated on her previously my ECU is a obd1?Speedo is a plug on top of trans under the intake tube near the firewall. If you have a 1plug dist then you need an obd2 engine harness from your model, yr car it can be a single cam it makes no diff so it should be easy to source. When you remove it use a sharpie and lable every plug you remove and or take pics to help with the install. Bet 95% of the troubles go away.
that page is absolutely amazing it is definitely definitely gonna help. Just to verify this is the section for the engine car and ecu i have correct?https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-honda-engine-swap-wiring-guide-vtec-non-vtec-2987229/
Give this a good read theres a part midway down says obd2 using p75
