gonna be reading a ton of this all night.https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-honda-acura-engine-wiring-sensor-connector-guide-3146770/
Honda-tech has all the info you need mostly in stickys give it a thunb through
Sent from my boujea ass phone
hopeing to have new harness by this afternoonIf you keep the obd1 p75 i dont believe the obd scanner will work but you know how to retrieve the codes as you showed in the vid. I personally would keep the p75 and get a new harness and go from there. If i had to guess the harness in your car was hacked maybe to add gauges of some sort but it was a poor attempt. Your on the right track now try and source a harness and i think you will have alot of fun with the car.
Its getting there !!! Harness feed into engine bay. How ever in such a rush i did not check my sharpie and had nothing to label things with lolAww s**t looks like a fun car is about to be had...
will do. what about the other wiring stuff i assume i need to do all thatAs long you lengthen the correct harness any wire will do. I suggest using heat shrink connectors or solder joints.
Dont worry about this till and if you add a vtec head..Do i need to do all this??
If you have a non-vtec civic you will have to perform these mods to your EWH in order to be compatible with an OBD1 VTEC engine: (1) add VTEC wiring (2) wire in the KS (3) *perform the IACV mod
Working on vid its uploading... Im really trying here getting frustrated tho. It honestly looks like the harness i took out was spliced all over cause nothing reachs for jack s**tPics or vid, its a honda Honda swap what dont fit?
