and this does what?24-7 said:with sleeves you can replace the individual cylinders.
silentdaredevil said:and this does what?
silentdaredevil said:im not really sure what sleeves do is it so u can have a bigger piston or what im a little confused about what its used for
extremly helpful thanksExospeed*com said:Well theres 2 main reasons why racers choose to sleeve their block. 1 is to be able to handle more boost than the stock block can handle. This usually is recommended at 15psi and above for B-series motors and 12-14 psi and above for D-series motors. I know you can be succesful with more boost than this on a stock block. But this is just a conservative guideline on when to Sleeve your block.
Another reason is for bigger displacement. This is more common in All Motor setups. In an all motor setup, you want to sleeve the block to increase the piston size to get more cylinder volume. You can go bigger bore on a turbo motor as well but its not the main reason that racers go this route. A common example to go big bore on a B-series motor is from a 1.8L LS or GSR block which is an 81mm bore. When you bore to an 84mm, it becomes about 2.0L Keep in mind on a b16, an 84mm bore only takes it to about 1.8L
The bigger bore increases the torque on an all motor setup.
WIth a sleeved block, theres limitations on bore size too. All Motor is max 87mm bore on a B-series and reliable bore for street is 84mm bore. For turbo we usually prefer keeping it at 81.5mm but can be bored to 84mm if thats your preference. The reason I personally believe big bore isnt needed, is that you can make the Large HP numbers on the 81mm bore. Bigger Displacement is good, but not totally necesarry since you can just increase the boost on a turbo motor.
I can go on and on with this subject, but these are the basic facts on choosing the right sleeve size for you.
Wil
What do you mean by against conventional wisdom. If you see the type of blocks most racers use. Its an open deck sleeve. If you do a random survey of people that have sleeved blocks. Majority will have open deck sleeves.handlebarsfsr said:exospeed, im curious as to why it seems you use open deck sleeves, which seems to go against conventional wisdom.
What is that supposed to mean? I have a full time job workin 40+ hrs a wek. The only bills I have is a phone bill and car insurance. I try to save money to fix my car. I'm not goin to be able to afford a turbo for awhile. I'm getting the car ready for turbo. If I save money then I should be able to get a turbo by next summer.Mr. Lin said:It must be nice to be 17 and be able to turbo your civic.
Oh, The only way I have the job I do is because I got into some trouble in school and decided to quite and get my ged. It was either get my ged or be in high school until I was 20 or somethin like that. No it's not because of bad grades. I made decent grades and never got held back. I just made a few bad decisions. I just try to get as much money as possible to fix up my car. It's one of the only things that make me happy.Mr. Lin said:Yeah, I wish I was able to have the money for a car and the time.
I work 36hrs/week because that's all they allowed me to get and now I can only work 15hr/week because of soccer and school... not to mention the fact that I have to help my father prepare the house for sale.
werd.. 8)Mr. Lin said:It must be nice to be 17 and be able to turbo your civic.
Looks wise, the open deck sleeves have an open coolant passageway, the area around the cylinder walls itself.I Cause Cancer said:whats the differences between open and closed decks?
