Turning up Boost
BoostedREX
Hey I have a turboed zc motor on a CRX it is running five psi but I would like to run 7 first is that safe for that motor and how would I go about doing it I hav a boost controller but only have somewhat of an idea can anyone help.
deaconwagers
...now rockin an integra
what kind of fuel management are you running?
King Bob
The life'o Riley
I dosent sound like you set up the turbo yourself ( forgive me if I am wrong). Just ask the shop or guy who built the system. Or give us a more detailed mod list it really depends on the way you are set up. But 2 more pounds of boost is not much, do you have a bov? or can you meke changes with the boost controler? I would'nt tamper with it unless you have a boost guage that you know is accurate. If you go f**king with the bov with out any way to check your work you will prolly wish you had a shop do it.
BoostedREX
it has a greddy bov with the apexi sfac managing my fuel and air plus I do have a boost gage and air fuel gauge too. That is the setup just thought I try to get some ideas (this car is a project I'm just trying to keep it away from shop as much as possible.) Thanks!!!
Handlebars
None Taken.
dont up the boost. safc is an awful way to manage fuel, and you dont mention if you have larger injectors or not. until you can get a proper fuel management program- uberdata, crome, turboedit hondata, aem, etc, i highly suggest leaving it, or you risk blowing up your motor.
Billy.
Has returned ;-)
King Bob said:
I If you go f**king with the bov with out any way to check your work you will prolly wish you had a shop do it.
i dont run boost and i dont have much experience with it, but dont you adjust the wastegate, not the BOV to change your boost levels? maybe ive misunderstood how it works exactly
eggie75
2 psi ain't much... get better management then turn that boost up to like 10-15... then u'll be smilin
rickles8099
Faster than you
yeah.... and blow his rods. if he goes with some good management he can run 8 psi easily daily driven. but the main thing to watch is the size of the turbo. if the turbo is small he can even get away with 10 - 12 psi of boost. but if it is a big turbo... he can only go with about 8 psi.
stealthy
4 Doors For More Whores
more info is still needed.turbo size?injectors size?
and dont listen to eggie,thats retarded to tell some that,idiot.
stealthy
eggie75 said:
lol... yeah... :smackself
if your being sarcastic then you are even more un-intelligent.2psi can make or break a setup.no?and to tell someone they can run 10-15psi is ignorant,ragardless of the fuel management.what about injectors?what about fuel pump?what about turbo size?huh?alot more goes into changing boost levels than you are obviously putting into consideration.and do you realize how much of a difference 10 psi and 15psi is?just stop now before you get even further behind.
eggie75
oh god... so anal... you're asking setup questions from someone that doesn't know how to turn up the boost w/ a boost controller. seriously
obviously turbo size, cr, fuel management , delivery blah blah blah it could go on and on - u can hear cases on opposite extremes - i know 2 ppl that run 12-18lbs daily on stock ls internals. zc has ideal cr for a turbo. he said he's running 5lbs now. what wastegate comes w/ a 5lb spring? a small one. you can criticize every word that i say, but bottom line its my opinion and you need to relax cuz u my friend are an ass.
stealthy
yes,im an ass.no,im not your friend.
dont give your OPINION to anyone when it could result in a blown motor.use pure facts.get it?
Bouncer
safc is an awful way of fuel management? ive seen plenty of cars run safc and never blow up due to fuel issues.
Inigo Montoya
powered by boost
shut up Bouncer, we don't like spreading bad information on CC.
sure it may have worked, but there are FAR better setups out there.
f**k, some people don't even tune their car, they just retard the timing and slap a snail on. Does it work, sure. Is it reliable/safe/optimal..........
FRODO
Bouncer said:
ok whatever
No heys right...and for the same price you can get your ecu chipped with whatever program you want to run and prolly a dyno run or two. so Safc is dumb...buttom line.
