Got my xterra on the ground before I went back to work.
Sent from my iPhone using Tapatalk Pro
Going to go fracking?Still in North Dakota. Planning on being in PA and Ohio starting around October.
Im already fracing. Should be consulting out there.Going to go fracking?
You probably will end up above Williamsport then I'm assuming, lots of that going on up thereIm already fracing. Should be consulting out there.
Not entirely sure man. Will contact you when I have more info.You probably will end up above Williamsport then I'm assuming, lots of that going on up there
Sounds good. Now get back to work on your vehiclesNot entirely sure man. Will contact you when I have more info.
Kinda hard from 3 states away homieSounds good. Now get back to work on your vehicles
I would do some interesting things to get my hands on that carFigured I'd post my hatch up in here a bit. Maybe I'll setup a build thread, but I rarely follow up with those kinds of things haha. She's finally on the road after three very long years of rebuilding the motor. The previous owner had swapped in an H22 and it gave up on me at the beginning of grad school. It was then placed into the garage and slowly transformed into what it is today. Came with a full 99-00 conversion that I am still reverting back to the correct 96-98 configuration. I believe the only thing "original" from the previous owner is the shell and rear trunk. Everything else had been replaced or fixed.
This is not as interesting as your SEMA pick up build!!I would do some interesting things to get my hands on that car
Can't forget your rootsThis is not as interesting as your SEMA pick up build!!
Should I mention the motor dyno'ed 217hp/151ft-lbs on 93 pump gas with a 60mm exhaust and conservative timing...
