h22 toooo heavyyyy
type r head is good. it comes with a mile port job from factory. if you want extreme and planning on have your head ported/polished, then go with a b16 head. type r heads are worth $, jus the way they are. once you modify them, by porting/polishing, u jus took away their valueOriginally posted by anfrey
actually, a b20 w/ a b16 head works much better. but regardless, b20vtec is going to be the most expensive option, especially if you like to drive hard.
oh, not saying higher compression is better for turbo. lower compressio is better. m jus trying to say, that since teh ls has a lower CR than a gsr, stock, u might be able to get alittle more power out of it than the gsr. but if you fully build both motors the gsr will prevail. and fully built means forged low compression pistons along with all the other goodies.Originally posted by ill3galdr1v3r
but if u say the gsr is better even tho it has higher compression, if thats the case then wouldn't people be turbocharging b18c5's(type r motor)?
not trying to prove you wrong sleeepy808 i was just wonderin...
