Is it hard to replace?
Sent From EVO LTE
Not at all. 32mm for the axle nut, 17mm for the lower ball joint and strut fork.
Loosen the axle nut BEFORE you Jack up the car and take the wheel off. You'll probably need a pretty beefy breaker bar, or, just use your jack handle on your ratchet/breaker bar.
Once you get the axle nut off, go ahead and break the wheel nuts loose, then jack up the car and support it properly.
Remove the wheel and tap the axle into the hub a bit, you won't be able to push it all the way through, you just want to loosen it.
Next, remove the cotter pin and castle nut from the lower ball joint and give the lower control arm a good whack with a BFH, the pressure of the suspension will pop them apart, no need for a pickle fork
(CAUTION! MAKE SURE NOT TO HIT THE BALL JOINT. IF YOU BOOGER UP THE THREADS, YOU'RE SCREWED, YOU'VE BEEN WARNED.)
Next, remove the through bolt from the strut fork that goes through the lower control arm.
Pull the control arm down and move the fork to either side. One side is better than the other, but I don't remember which way to go.
Now push the axle the rest of the way out of the hub while holding the knuckle/hub /rotor/caliper assembly out of the way. Drop the axle shaft down through the strut fork and move under the car.
Place a pan or some rags under the tranny where the axle goes in.
Using a small prybar or beefy flat head, pop the axle out of the tranny.
Axle is out, time to resemble.
(now is a perfect opportunity to replace your axle seal, just sayin )
Slide the new axle into the tranny until it stops, don't try to seat it just yet, you might tear the boot.
Back out from under the car, use a bungee or have a helper hold the knuckle assembly out of the way. Get the axle as straight as possible. Put the OLD axle nut on the new axle, but leave a few threads unthreaded. Give it a good whack with a hammer until you feel it pop into the tranny and seat completely. Double check that there are no gaps between the axle joint and tranny.
Line the axle up with the hub but make sure you put the strut fork back over the axle first, slide the axle into the hub and put the ball joint shaft back into place in the lower control arm. Replace the castle nut, tighten and replace the cotter pin.
Line the strut fork back up and put the nut and bolt back, tighten up.
Put the new axle nut on hand tight, put the wheel back on, and tighten the wheel nuts. Put the car back down, yank the s**t out of the parking brake, and tighten the axle nut. Jack the car back up take the wheel back off and stake the axle nut. Replace wheel, tighten, lower.
Congratulations. You just replaced your axle
(don't forget to top off your tranny fluid)
Tapatalk2 T-Mobile Galaxy S3
