What the F-word did I do?
mattliston
I'm sure you know, because you've obviously had both and replaced both of them smart ass. Double check your own dumb ass. I've already searched for you dildozer.
O know partsstore people are f**king retarded, and you probably had one switched
That website i linked uses DEALERSHIP NUMBERS
no need to be rude. Im not the person sitting on daddy's d**k
12.8:1 Ls/vtec
IT'S OVER NINE THOUSAND!!
^^^Have you personally held the parts in your hands? #'s on the internet are nothing. One the fuel enters from right beside where the line is, the other it enters from the bottom.
I can't make you learn. You're too busy trying to prove me wrong to even know you've neglected even looking for yourself. I don't have to look b/c I have done several in real life. Just look at some engine bays at the fuel filter, notice some are tilted and some are not. Notice the fuel lines angles, notice where the fuel enters the filter.
^^^There you go, spoon fed
mattliston
Ive done plenty of work on 5gs and 6gs and dozens of del sols
Im telling from experience dude
maby models like the VX or CX have different style?
obviously you made your mind up they have differences
but I can call any partsstore and order a fuel filter for 92/3/4/5 and get the same part number and same filter
same with del sol
96-00 is bottom feed
mattliston
switch the bracket and fuel line, and BAM you cna have either or depending
Pooponurhead
Quivering Member
Look, this thread is not a pissing contest. It's a "Help Me" thread. So let's try that for a change. Kthanx
95exb18
I dunno man. Its definitely causing idle issues...really rough. It almost stalls when I stop. Also bucks terribly at lower rpm in any gear.
hey man mine is doing the same damn thing. and its weird cause i was having oil leak from my dizzy too then i fixed it and it is having these same problems, does it often shoot carbon out the exhaust?
