Well I have changed a few things around and here is my updated build list.
JE/SRP 9.0:1 Pistons w/ JE rings 75mm
Eagle H beam rods
Stock Crank
ACL Race bearings
WORP Speed Mini Ram
Holset H1c
Tial 38mm WG
Custom 3" turbo back dumped under car
18" long 3" dia DynoMax race(bullet) muffler
Cometic 5 layer HG
Neptune RTP/Demon with PWM boost control
AEM 5 bar map sensor
PTE 1000cc inj low impedance with resistor box
B&M AFPR
Aeromotive fuel pressure gauge
Wally 255 lph
Aeroquip -6AN fuel line with Russell adapters
Precision Turbo FMIC
Greddy BOV
Innovate LC-1 w/ XD-16 stand alone kit
2.5" IC pipe
ARP Head studs
H23 60mm TB w/ port match z6 intake
ACT Extreme Clutch kit 6 puck solid hub with 2600lb pressure plate
Moroso deep sump oil pan
Aluminum 2 core radiator
Mishimoto upper and lower radiator hoses
JIC Majic FLT-A1's
Blox LCA's with new ES urethane bushings
WORP Speed rear lower tie bar
GSR rear sway bar
Nuespeed front and rear camber kit
Goodridge SS brake lines
B&M Pro shifter
Custom catch can with all 5/8" barb fittings
WORP Speed harness bar
Integra/Civic EX 10.3" front rotors with 7/8" master cylinder
Semi tucked engine bay
14" HX wheels
M3 lip spoiler
2g DSM weighted shift knob
MagnaCore 8mm plug wires
NGK Racing noon resistor plugs R5671A-8
Power steering delete(looped system with a vented reservoir)
