97 Civic EX Engine Swap Help
weirdvein
Need expert opinion about engjne swap from D16 to B18 motor. I plan to spend at least 5K including labor.
Rand0m
Adamantium Member
what do you want our opinion on? all you said was what you wanted to do, and what you were gonna spend...we are gonna need a little more than that
btw, welcome to club civic =)
LatinEM2
La Raza #2
yes what exactly do you need to know??
weirdvein
B18C, B18C5, etc. or B16, B16a, B16b, etc. Basically, all I want is a good stock 180hp or more and most importantly reliability. What B16 & B18 motor that is a direct bolt in to 97 Civic EX? without any welding to the chassis.
LatinEM2
La Raza #2
All those engine bolt right in without any welding...
Rand0m
Adamantium Member
try and find a deal on a b18c5, and get some friends that know what they are doing and will either swap it for free, or real cheap...you might be able to get it done for under 5k, and you would have a real reliable, 190 hp....if not, then swap a GSR motor....little cheaper, but not as fast
anfrey
OG スバリスト
i suggest you do some research on the different engines before you embark on this project.
DXisb16a
yea do research, its always good to check out ur options before buying, and think about what u want, do u just wana swap? and than leave it stock or would u like to add boltadds ecu etc... just think before u spend, cause u can only spend once, but you can research and look around many times. and welcome to CC
weirdvein
All I want is just a swap that will drop to my 97 Civic EX without any weld to the chassis. Also, reliablity and stock 180HP or more. I found a GSR motor for $3595 at www.ardperformance.com that includes Engine, 5spd, ECU, Harness, Axles, Shift LInkage, and Mounts. It is also available with OBDI & OBDII. What do you think?
LatinEM2
La Raza #2
Looks like a decent price. click here but u can't find them cheaper if you look around...
anfrey
OG スバリスト
just about any b-series will drop straight in... (well, maybe except a b20a, but u don't want that anyway)...
since you have an odb2 car, go with an odb2 swap.
what are your plans for that engine?
anfrey
OG スバリスト
u mean the transmission.
LatinEM2
La Raza #2
weirdvein said:
I forgot to add one important option. The motor should have a LSD.
The only one's with LSD's are the Type R engines...(tranny)
anfrey
OG スバリスト
yeah ITRs come with an LSD stock. you can always get an aftermarket limited slip
weirdvein
Headers, Cat-back, ECU upgrade, etc. Nothing major. I wanna run stock.
weirdvein
Any other B series motor that comes with stock LSD?
What about emissions? Will it pass?
Has anyone done an engine swapped?
Rand0m
Adamantium Member
take your 5 grand, sell your car, and then buy my hatchback....its got the b18c5 motor, lsd tranny, and a bunch of other good stuff...well over 180hp, and super reliable 8)
anfrey
OG スバリスト
there you go. you'll have a better power:weight ratio as well and be much faster
