thank you! I definitely have fun with it every day hahaYou have a very sweet ride . Have fun with it.
Sent from my SM-G900V using Tapatalk
thats good to hear. their prices are pretty good too. i was planning to use their full size dc2 k swap radiator when that time comes.Yeah, I was very please with this limited use put on the half size Koyo. So I'll be using the full size from Koyo.
Yeah I've heard plenty of stories about mishimotos poor quality including the drain magnet dislodging itself. Found mine in my thermostat. Luckily I haven't had any other problems. The wheel offset isn't bad as is but they're only 7" wide +38 so there's still some room in the fenders especially in the front. A 7"+25 should sit close to how a 8"+35 does and those are the perfect specs imo. If I were to run anything wider than a 205 on a 7"+25 I'd prob run into problems though. It's a daily so the wheels feel great as they are on the back roads I take to work haha.Yeah, Koyo prices are right off of Mishimoto from looking around. And Koyo is much better in my opinion. From a cooling aspect, my numbers were better with the Koyo. When I flushed the Mishimoto before install, it was like half the guts flushed out of the thing. I couldn't believe the amount of aluminum that came out. Koyo flush, nothing.
To the K1's, I think that the +25 would poke out. What you have on currently looks to sit perfect.
Thanks man I appreciate that!Looks really good dude!
My rear quarters wound up being pulled slightly from the rolling process so that does afford me a few mm there. Also I'm only on 205s so the sidewall is pretty squared up w almost no bulge on x7 similar to how a 225 fits on a x8. The 15x8 +25 enkeis I had definitely poked too far for a 225 and would've barely fit with a 205 but I don't want stretched tires. That's why I'd rather stick with x7 for the daily and save a purchase of x8 +35s for my integra. test fitting would be the safest thing to do before making a purchase but I'll prob just ride these for a while. I need to dump money into the other car and get it running already. I have a pair of garbage 5mm spacers that I could stack to get an idea but I need arp lugs first. Those along with a press are the next on my list of purchases.You might want to try and do some test fitting before you go with a +25. I've run x7, x8 and x9 up front with the most being a +35 and its flushed out. The difference is that I have run that with a 225/45. The x9 I have spaced out to +31, and it sat under a rolled OEM fender and now with a little push from the TrackLife cutouts. But it did fit under the OEM. I'd just hate for you to get into a bad position.
Thanks man! It's not too killer yet though lol.killer setup
Hey Guys,Yeah, Koyo prices are right off of Mishimoto from looking around. And Koyo is much better in my opinion. From a cooling aspect, my numbers were better with the Koyo. When I flushed the Mishimoto before install, it was like half the guts flushed out of the thing. I couldn't believe the amount of aluminum that came out. Koyo flush, nothing.
thanks man i really wasnt sure how bad the carnage was gonna be when i opened it up. it definitely couldve been a lot worse.Nice troubleshooting!
you and me both man! i was desperate and couldnt think of any other way to do it. it was really the balls that held the inner race in there but keeping them evenly spaced was crucial. as i was tapping i could see the inner race pushing out pretty far but it just barely held on enough to pull the whole thing out in one piece.Wow, this will hereby be known as "the paper towel trick", i can't believe that held !
