Well I've been way slack on updates so here is a bit of whats been going on since Jan...
More Jan -
Got some small stuff done. Rerouted an EDFC cable off of the firewall and out of sight. Decided to keep the Civic cmc and use the ChaseBay tuck clutch line so all that mess came off and changed. Pulled off some brackets and painted them. Changed the fuel filter. New O-ring on the rad drain plug.
Feb -
Really been to busy to work on the car. Lots going on during the week and not really anyone that can come over after work to help. Traffic here doesnt make it worth trying to work after work...lol. Weekends have been rather busy since getting back from Cali as well. I'm hoping to get some work in the weekend though. I am going to try and get some stuff done this week that I dont need help with to help prepare.
I did this last week change the connector on the Rywire alternator side as it was broken (bought the harness second hand). Also pulled the oil pan off the ITR motor to swap on my old Moroso. Yeah, B16 and B18C oil pick ups are different...lol. AND the pan I have doesnt work work the ITR trans brace. So, back on goes the OEM pan. I was only changing it because I had it.
March -
I cleaned up the AC, PS and Alt brackets and prime/painted them and then put back on the engine. And as I plan on running the Rywire harness though the OEM harness location on the firewall I started pushing connectors thought the boot. I had to cut it back a little but it wont matter after I'm done and tape it back up. I'll have just 1 connector to de-pin I think and I'll get it all through
Got the last connectors through the boot I had to de-pin them to get them though. One pin wouldn't release as the lock lifter was already messed up. I got it out though...lol.
I've got spare "junk" harnesses that I can rob from though and I've replaced the connector. I've now got the Rywire harness with an OEM firewall boot
A friend and I took the day off and finally got the engine off the stand! Changed out the rear main seal, put on the Spoon heat barrier tape for the oil pan, Alt belt, put on the Rywire harness, flywheel, clutch/pressure plate, mounted the trans, and moved the whole deal over to the other bay and lowered the engine/trans into the bay!
![Very Happy :D :D](/forum/styles/default/xenforo/smilies/icon_biggrin.gif)
Couple issues to work out as the AC belt was way to small. Part number checked out but def not right. Ordered another belt for that and some bolts. Rear mount bolt had some threads messed up at the end and the die wouldnt cut them back as they were to low on the bolt. Used it to support the engine as it would make a couple turns though before hanging up. Driver bolt, wouldnt fit. Changed from the Hasport silver mounts to black mounts...through hole is smaller on the black mounts. Ordered a new one for that side. Goal for the day yesterday was met
![Smilie =) =)](/forum/styles/default/xenforo/smilies/icon_smile.gif)
Got some good work in. Pics to follow as I cant get to my photobucket from my work computer...
So the black series Hasport mounts I got from a friend have a larger driver bracket. My old silver ones I had no issues at all with PS/CC mounting.
Had to trim out the PS res to make the bracket fit. Also had to remove the bottom bracket of the CC unit.
And the Si throttle cable bracket hits the ITR IAT sensor. And the way the ITR bracket sits the cable is off from the mounting. Serge said it would adjust ok to use but I just flipped the bracket and it now sits in the right spot!
RyWire subharness, depinned on one end as I was going to start to extend the wires. But, there were some cut and resoldered wires that I wanted to check. And one thats cut but looks like it should be connected. I'm going to just call RyWire on Monday and see about having a longer subharness made/sent. I dont want one thats hacked up as much as this one...
Since the RyWire harness doesn't have the Alt cable in it I have to run one. The cut ITR harness that came with the swap had an uncut full length Alt cable in it. We cut the loom off, pulled it out and I ran shrink over it and then put expanding loom over it
April -
Well, I got the RyWire sub harness Thursday before leaving for NC for a few days. I packed up a kit to work on it in the hotel while the wife was at her conference. Get all things laid out in the room to prep for making cuts and solder...forgot the dang jewelers screw driver to depin the new connector harness! So, I made Friday a lazy day and did nothing.
Saturday, met up with some EM1Crew friends at a meet in Winston, about 1.5hrs west of where I was in Durham. Took the TSX out for the day while wifey was again in her conference
Sunday, pulled the new harness apart and got all the soldering done, HondaBond around the wires and then marine heat shrink sealed the wires for environmental controls
Then to run full length shrink to clean up the look...easier said than done as it was like 4ft or so of wire to push though and wire doesnt exactly just push through shrink like that...lol. Sooooo, I took a coat hanger and tied fishing line to it, pushed it through the shrink to the other side. Depined the other side of the harness so all I had was a free wire and then tied the line to it. Then, I tied another line to it and pulled the wire through the shrink. Get to the end, tie the two ends of the fishing line together and pull back through to start over. I had to do it that way rather than just pull one way and then the other as one end the pins has rubber environmental seals that would hang up and tear. I didnt want to take a chance at damaging the seal or hurting the pins. In all before I had to quit to get some other stuff done I got 6 of the 8 wires pulled into shrink. I'll finish the last two tonight or tomorrow and then run it into the expandable loom to finish the harness off.
Getting started in the pull in...
Line tied off to go each way!
